Results 1 to 2 of 2
    Jun 2008
    Evap coil condensate plumbing
    A home owner question.. With a York full case evap coil, is one condensate drain installed the norm or should the "secondary" drain be installed also? I.E. two drain pipes running into the condensation pump? Thanks.
    Lancaster PA
    Both should be installed/ran.
    Not always done though.
