Results 1 to 7 of 7
Thread: Keeping Up
07-19-2008, 09:35 PM #1
- Jan 2007
- 24
Keeping Up
Had A 2.5 Ton Condenser Installed With A 2 Ton Air Handler Cooled Great But The Condenser Finally Went 18 Years Old Got It Off A Job I Did. Put In A 2 Ton 13 Seer But Now System Has Trouble Keeping Or I Should Say It Is Dehumidtify Great But Room Temp Wonted Go Below 76 On A 95 Degree Day.the Old Condenser Use To Get It Down To 73 On A 95 Degree Day.the Only Thing I Did Diff Was The Unit Did Not Get Turned On Till 2 Because I Was Installing It Maybe Not Enough Catch Up Time Turning It On Late. I Would Think You Can Only Fill A 2 Ton Coil With So Much Refridgeant So 2.5 Tons Was A Waste I An Sure The2.5 Saw Some Floodback To The Compressor . By The Way Air Handler Is 2 Years Old 10 Seer With A .060 Piston The New Condenser Called For A Txv Or An 060 Piston
07-19-2008, 09:39 PM #2
- Mar 2008
- 205
07-19-2008, 11:09 PM #3
- Jan 2007
- N.E. Ok.
- 1,297
07-19-2008, 11:13 PM #4
Your capacity is gone. 13 seer condenser with a 10 seer coil, is not only lost efficiency (which from what I have read here 13+10= 8 seer) But your capacity falls.
07-19-2008, 11:17 PM #5
You need a matched system bud. get a new evaporator coil to match with your condenser.
07-20-2008, 07:14 AM #6
- Jan 2007
- 24
would a txv help out a little
07-20-2008, 09:08 AM #7
It will help protect the compressor.
But it won't help to make your house any cooler.
