Page 4 of 7 FirstFirst 1234567 LastLast
Results 40 to 52 of 80
  1. #40
    N.E. Ok.
    could we get a picture a good service tech will have no problem finding the filter if it has one
    Here you go, i'll save my guess so as not to give it away
  2. #41
    Jun 2008
    west point, ga.
    Quote Originally Posted by captube View Post
    What you can't see that filter?
  3. #42
    Hmm
    [QUOTE=jhooker;1932738]I may have to do that. I hosed it off but it kept freezing back. We're running the sprinkler on it right now to unthaw it out.
    Well lets see THAWING it out I understand, you would melt the ice. UNTHAWING it out, how does that work, are ya gonna stick ice cubes to it.
  4. #43
    Quote Originally Posted by catmanacman View Post
    could we get a picture a good service tech will have no problem finding the filter if it has one and if it dont have one they will find that also i would just turn it off it will thaw in a couple of hrs it is better if it is not iced up when the service person gets there is it a package unit or is it a split system
    it was hard to get the camera very far away cause the panel is on the back. hope this helps, thanks.
  5. #44
    with everything so cold outside it should be getting colder in the house.
    i just checked and it has cooled down to 78 now. guess we'll just try it til monday and call the repair guy if we really need to.
  6. #45
    Unhappy
    Quote Originally Posted by jhooker View Post
    TRUST ME YOU REALLY NEED TO, YOU ARE KILLING THE COMPRESSOR.
  7. #46
    do you think it will be okay with the sprinkler on it?
    also, when is the fan blade on top supposed to come on?
  8. #47
    N.E. Ok.
    We need a picture with the sprinkler to be accurate.
  9. #48
    Well he is right, let me see your sprinkler set up
  11. #50
    N.E. Ok.
    I don't think a tech can help you , i'm thinking it's possessed
  12. #51
    Denver, CO
    Yes, you must be getting atleast 2.2 GPM on the unit for it to work we must see a pic
  13. #52
    Jun 2008
    Maple Ridge, B.C.
    If you hook up a few electric resistance heaters, or better yet a propane heater and direct them at your outdoor coil, this will rectify your problem. The problem here is that you have to force the "coolness" on the coil into the house. By heating it up outside you will achieve this goal and will probably even mange to maintain about a 29*f temp inside the house. Good luck!
