07-19-2008, 12:01 PM #1
- Dec 2007
- chicago
- 249
residential refrigerator/freezer temp issues
I'm having temp issues in the fridge side of my refrigerator. My freezer and ice maker are ok but the box temp in fridge is not cool enough. I've cleaned the coil and am in the process of defrosting the whole unit, any thoughts?
07-19-2008, 12:44 PM #2
call a technician to look at it
07-19-2008, 12:57 PM #3
It sounds like by cleaning the condenser and making sure the evaporator coil is thoroughly defrosted you have done everything you personally can for the system. Monitor the temperature for a while and if it doesn't come down you'll need to call a technician in to take a look at it.
Good Luck
07-19-2008, 04:04 PM #4
Make sure you have good air flow circulating into the refrigerator
07-19-2008, 05:21 PM #5
- Jul 2008
- South Shore,Long Island
- 274
