Results 14 to 16 of 16
    Denver, CO
    Quote Originally Posted by jackt View Post
    Replacing the cap tube may not be hard but, installing the correct size and length can be a pain. Its real important to have the correct one. With your system equalizing so quickly, I would guess that your compressor is bad.
    This is why I say don't mess with the cap tube it must be the exact same size and length, and you can not cut a cap tube you must have a fatory replacement available
    Jun 2008
    South Carolina
    I've installed many cap tubes that need to be cut in the field for whatever application you may have. The roll came with a chart to tell you what length you needed depending on a lot of different factors (refrigerant,static or fan cooled). I usually scored the tube all the way around with a small file and then it will break apart without leaving any inside blockage. I guess I'm showing my age because that use to be the only way I could purchase and use them.
    Quote Originally Posted by markettech View Post
    I haven't been around much in the last couple of months..........but my memory isn't THAT short.
    http://hvac-talk.com/vbb/showpost.ph...3&postcount=32
    Good luck
    Its been a while but
    When I have trouble remembering something I used to blame my brain and everything being compressed through my cap
    and suspected it was just too tight.
    Now I can tell my mind had just been leaking out slowly over time when I loose my cool
