Results 14 to 25 of 25
    Alabama
    Quote Originally Posted by lowridemazb2200 View Post
    Yeah this is what the supervisor gave me was a one heat one cool thermostat on a 2 stage ac unit. I thought that was messed up. Why have the customer pay for a nice unit and not give them all the options the unit is capable of doing.
    I have the G61MPV series furnace.
    here is the wiring diagram that is in the furnace manual:
    tstat control term. strip outdoor unit
    w------W1
    r-------R
    g-------G
    c-------C------------------c
    Y2
    y-------Y1-----------------y
    That is how I have it wired up
    The wiring diagram for the outside unit should be in the outdoor unit.....
    Maybe your superviser needs to read the manual..
    burlington county n.j.
    Quote Originally Posted by superd77 View Post
    Three won't work, Dude!!! It will never go into high speed!!! Especially if you don't hook up the blue wire.
    Dude........... xc16 only has Y1, Y2 and common to hook up to.
    how many wires do you need????????
    Alabama
    Preferred Lennox dealer
    Quote Originally Posted by t527ed View Post
    According to the Lennoxdavenet.net , You have to have FOUR wires for the outdoor and indoor to work properly!!!
    There is a blue wire in the outdoor unit that tells the A/H it is in second stage. If it is not hooked up it won't work!!!
    Apr 2008
    I will tell my supervisor to get me a 2 cool 1 heat thermostat with dehumidification control. Then the customer will be getting what they sold him.
    according to this diagram http://tech.lennoxintl.com/PDFs/535286wia.pdf
    there are only 3 wires to hook up on this unit.............
    he is working with a gas furnace and straight a/c right?????
    you may be thinking of a xc21 unit with the protection module, they need 4 wires.
    Apr 2008
    You are right I have those exact ones in the odu.
    you still have other problems, you should at least be able to make it run on low stage with what you have......
    Jun 2008
    west point, ga.
    According to RDP the pro 8000 will serve you well.
    Just curious , what 2 stage compressor does lennox use, I havent seen any around here yet that are 2 stage, Is it the copeland ultratech
    Apr 2008
    the guys who done the trim on it were not communicating well with each other. (that is a little obvious though) When I first got there they did not even use the same colors. So, I had to rework all the wiring. I guess I still need to rework all the wiring. This house has 4 units and they are all the same type. So, when I get it figured out I should be able to get the others one right away.
    Alabama
    My bad!!
    The link I found said 4 wires. But it didn't list them. I found another that did. C, Y1, Y2, and L. L is not used unless a communicating stat is used. Sorry!!
    XP16 has the blue wire I was thinking of.
    Western NC
    only had to rewire.....
    I've been on start-ups that took over a week!!!!
