Thread: Duct question
    Duct question
    Can anyone tell me how to install a vent in ductwork?
    The house was built in the mid 60's, so the ducts are rather large. We are building bedrooms in the basement & need to cut two more vents before installing drywall on the ceilings.
    Any help would be great!
    That's an easy one. Call your A/C contractor. This is a D I Y question, which we don't allow. Sorry.
    Central Maryland
    Quote Originally Posted by crazymama View Post
    Where's the return air going to come from?
    -HF
    Go out and buy the expensive tools like the ones I have. And its easy.
    Of course, those bedrooms are going to be cold, summer and winter, doing it the way your going to do it.
    You need a Pro.This requires design skills that not allPros have.
    Call around and ask" Can you doa Man.J load calc,Man. S equip selection,and Man.D duct design form my addition?"
    Keep dialing until you get 3 yeses.
    a question not asked is the dumb one. but here thier no d i y I would recomend you call some one, you see air flow is a science in the hvac its not cut and dry as one would think cutting a few hole, s in the duct with out checking will cause you more trouble the its worth you may end up loosing and not gianing annything at all so pleas before you cut call a professional to come out and make sure its the right thing to do.. best of luck to you.
