Results 1 to 13 of 15
    Panama City, FL
    Adapter Curb.....Check.
    Filtered outdoor air....Check.
    Better get the maintenance contract and include new flex every fall. You just can't make this stuff up.
    You can't learn a thing with your mouth open.
    Man, that is a deluxe install there, has a filtered fresh air intake and all, what are you complaining about?
    Looks like the kind of crap I found on some K-Clinics in the DFW area, only the contractor they were using dressed it up with a protective enclosure around the flex duct......made of ductboard....
    RSES Certificate Member
    RSES-SWRA President
    Sep 2006
    Here :)
    hotandtired YOU'RE FIRED ! ...
    Apr 2008
    Pluto
    I love the red-neck economizer.
    Not as lean, not as mean, but I'm still a hardcore, ass-kicking, hard charging Marine! Oohrah!
    Mid Michigan
    Got resistence?
    Austin, TX
    Ill be, I have a radio tower site set up similar to that, except flex goes in
    the side of the building where a small window used to be. The flex had
    completely shreded (took about 12 years though). They did not want
    metal duct, so I had to put new flex up with aluminized exterior.
    damn .. absolute crust
    Oct 2005
    Kermit, TX
    Atleast they splurged on the good flex.
    Zach
    Mar 2006
    OK
    But it's plastic, that makes it weatherproof doesn't it?
    Never knock on Death's door. Ring the bell and run, he hates that.
    Views expressed here are my own and not neccessarily those of any company I am affiliated with.
    thats a beauty! never seen anything like that before! might have a hard time adjusting the fresh air though...
    Central PA
    Residential version
    I seen the same deal with a residential unit. Someone put a self contained trailer unit on a house via flex ran through a basement window. At least the put a damper to shut of any air flowing outside in the winter. We removed the unit and put in a split system
    Arizona
    At least they used a top of the line RTU... NOT!
    Maybe that was one of those "DIY kits" from the internet?
    True Heavy Metal Geek
    Boise, ID
    The zip ties are per code though.
    Politicians need to be changed like diapers, and for the same reason.
    Mark Twain
