Results 1 to 2 of 2
    smaller condenser than coil
    Can a Two ton AC condenser be added to a system that has a 3-ton coil? Are there adverse effects of doing this?
    Usually, its only 1/2 ton larger.
    A 1 ton larger indoor coil won't remove as much moisture as a 1/2 ton larger coil will.
