Results 1 to 13 of 34
Thread: target superheat
07-18-2008, 12:45 AM #1
- Mar 2005
- reading PA
- 20
target superheat
so ive seen a number of target superheat charts around but am wondering a calculation ive recently stumbled upon. wet bulb times 3,minus 80, minus outdoor ambient temp.. just wondering if most use a standard chart, try and go by what is on/in the odu, or mabey this calculation? any input is welcome...
07-18-2008, 12:51 AM #2
If the unit has a charging chart I use it.
If it doesn't and its a fixed metering device, I use that formula.
07-18-2008, 12:55 AM #3
Do you use outdoor DB or WB?
07-18-2008, 01:07 AM #4
Outdoor DB.
07-18-2008, 06:19 PM #5
Same here. I use that formula, unless I have a manufacturers chart to go by.
07-18-2008, 06:20 PM #6
Do you guys take wb at return and supply and then average them?
07-18-2008, 06:36 PM #7
- Mar 2008
- 657
is there a rule of thumb SH? i've read nothing below 8 and nothing above 30 true?
"The things you own end up owning you. "
Tyler Durden
07-18-2008, 06:57 PM #8
07-18-2008, 06:58 PM #9
if it's in the unit I use that, otherwise I use Trane's sliderule.
You can't fix stupid
07-18-2008, 08:00 PM #10
07-18-2008, 08:20 PM #11
07-18-2008, 08:26 PM #12
07-18-2008, 08:29 PM #13
seems like I have heard others say they take both and then average them to account for "mixing" I have just been doing return only, but tested a few by averaging, not a huge difference but about 2-3 degrees between methods. What is your theory of reading close to db if close to coil?
