Results 14 to 21 of 21
Thread: Manitowoc puzzler
07-18-2008, 09:18 PM #14
07-19-2008, 10:27 PM #15
can anyone read the post between this one and squids
I'm seeing things and then not
Could it just be me again
07-19-2008, 10:27 PM #16
Banned
- Dec 2006
- Middle Tennessee
- 11,347
well, they are correct about the clean cycle
what's the evaporator plate look like, is it worn out?
can you see any copper showing through on the evap plate
sometimes a worn out evap will try to harvest but some of the ice will stick on the evap surface creating havok
just a suggestion!
07-19-2008, 11:40 PM #17
07-20-2008, 08:20 AM #18
Did you try switching it to clean then back to ice... thats how you get it out of the clean cycle
IE: It's in the clean cycle, you want to end the cycle before it's finished; switch it back to Ice then back to clean and then Back To ICE Again, This should start the freeze cycle.If your not part of the solution, You must be part of the problem
07-20-2008, 08:25 AM #19
Do they have a water softner? If the water is to soft, the water probe won't sense the water
07-22-2008, 11:35 PM #20“If You Can Dodge A Wrench You Can Dodge A Ball”
07-22-2008, 11:46 PM #21“If You Can Dodge A Wrench You Can Dodge A Ball”
