Thread: E-2 hook-up
    Banana Republic,Florida
    E-2 hook-up
    has anybody been able to do a direct connect to an e-2 with 3-4 more controllers with patch network instead of echelon and back-up the whole store from the bx each rx has their own i.p there is a hub but it give me a no port error if i use cross-over or cat-5e cable and if i use usb to 9 pin it gives me an error but i can go to each controller and back-it up but they dont drop the other rx's?any ideas?
    Orange County CA
    Quote Originally Posted by gatorfan9606 View Post
    Have you ever connected to an E2 before with a "cat5"? (crossover)
    You have to set the IP on your laptop to a close I P
    For instance
    RX#1 IP 2.2.2.2
    RX#2 IP 2.2.2.3
    RX#3 IP 2.2.2.4
    laptop IP 2.2.210
    Subnet 255.255.255.0
    Default gateway on E2=2.2.2.1 or2.2.2.0(I think I've even left this blank
    Edit communications in ultrasite to the store to one of the controller IPs like 2.2.2.2. should connect. If connecting to the router.
    Whichever RX/BX set ultrasite IP to that controller connecting to.
    Good luck
    florida
    lap top IP only needs to be one digit ahead of the bx.just go up one on the
    last digit.
    Educational forums are open.
    yes i have connected before.but each rx is not echelon together i know about the last digit been off by one and the l.a.n but if you go through the bx you only get the bx thier using cat 5e to each rx so when you unhook the cat5 of the bx to do an tcp/ip connection you stop comm between other controllers so you dont drop the other rx's?
