Page 3 of 4 FirstFirst 1234 LastLast
Results 27 to 39 of 43
  1. #27
    Quote Originally Posted by CMORAN View Post
    Thanks for the reply. I believe it is PXC16.2-E.A. On the 10S display it says BACnet 3.2 so I'm hoping that it will have BACnet capabilities; however, I've read that a license has to be installed to enable BACnet comms through the port. I guess I'll know more once I get to it through HYPERTERM.
    Thanks for the info.
    Yes a license is required to be able to communicate Bacnet
  2. #28
    Mar 2013
    Is connecting to the device via TelNet, the same as using the DESIGO firmware download tool, and choosing terminal once connected? What functionality does it provide?
  3. #29
    Telnet is hyper terminal via the command prompt over the Ethernet.
  4. #30
    Mar 2013
    Apologies, I meant hyper terminal. What functionality does it provide to you when connected to a Siemens PXC though please?
  5. #31
    Jun 2006
    Des Moines
    Full functionality via Hyperterminal. Of course, you can't backup\restore databases.
    Dingman from Iowa~
    "A lie gets halfway around the world before the truth has a chance to get its pants on."
    - Sir Winston Churchill (1874-1965)
    The Dingman's webpage, featuring the Ding_Z
  6. #32
    Mar 2013
    Are the controllers you're referring to Apogee devices? It's just I have a PXC-128u on the bench at work, and when I read this thread, thought I would give it a try, but to no avail. Mine is a PX Desigo device, replacement for Visonik.
  7. #33
    Oct 2013
    Wow desigo Is already here ? I have heard our office are starting to train our techs on it. I have worked for Siemens Building Automations for around 15 years so if anyone has some question about any I our parts maybe I can help just send me a message. I work out in the field everyday.
  8. #34
    Jan 2011
    McAllen, TX
    Are there any PXC controllers that have manual knobs like some MEC controllers? As in being able to manually modulate 0-10V output.
  9. #35
    Yes there is a part that takes the battery cover of the PXC and adds HOA switches. I do not have a part number.
  10. #36
    Nov 2009
    What is the deal behind a PXC coldstart? It seems that if you change the network name, ip info or bacnet info, the pxc dumps its programming and you have to load everything back in...
  11. #37
    Aug 2014
    If you change the IP, bacnet ID, BLN name, or system name all siemens panels coldstart. If the server is insight or desigo cc, it will reload the panel when it reconnects. If it doesnt reload, you can go the the dbfile and select restore from flash. This is assuming it was set up properly to be used on a 3rd party system. Proper set up would include saving memory to flash and setting to autorestore. If on a siemens front end, do not select autorestore, or the server will not reload it, and it can also affects trend collection
  12. #38
    Nov 2009
    Still, don't understand the reasoning behind the coldstart...if I change these parameters on an ALC LGE, it doesn't dump its setup info...just seems weird.
  13. #39
    Jan 2016
    I'm new in the industry and I appreciate any help you could give to me. right now I'm working with a PXC 36 for High Level Interfacing , My current project is to read power meters (Carlo Gavazzi WM 14-96) this device is ready for modbus RTU communication like PXC 36. I don't know where to start. My co-employee said that I need to create an isb. file but how am I going to do that? Another is how can I be sure that the isb. file is correct or even what I am doing is right?, I have the software APOGEE Insight V 3.13 installed in my computer., I have been working with this project for months now and today i feel down because no matter how I am eager to search for technical docs or manual I just can't get the exact thing I need.
    I hope you could help me with this.
    Thanks, and God Bless
