Results 14 to 18 of 18
    Update
    Finally got the wiring redone and the settings set correctly. The line set was a pound low on fluid and the lineset was pintched. However, today I noticed that the pureair was installed incorrectly. Notice the filters are in backwards. Should be paper/lights/metal. 3rd service call.
    http://picasaweb.google.com/Christop...ton/Tranewreck
    Virginia
    some mistakes were made that should not have been made but it sounds like they are taking care of you , that is a nice system get the ten year parts and labor if you have not done so yet
    Aprilaire 600
    Shouldn't the discharge unit be on the supply side, not the return side?
    http://picasaweb.google.com/Christop...38952889092450
    600 has no discharge side.
    Rochester, MN
    Quote Originally Posted by Doublechecking View Post
    No, it don't matter.. I know a lot of us like to have the unit itself on the return.. That way if there is water problem, you won't be dumping water down into the furnace, and blower.
    On your transformer, I would of mount it inside the furnace, and not sure if they took advantage of the HUM hook up in the junction box or not?
    Here is mine.
    I see they hooked up the 2nd stage heat as they should of.. Hopefully they got the t-stat's advance settings set right.
