Results 1 to 9 of 9
    new trane air hander hum when unit is off
    Yesterday, I had an ac change-out and installation of a new Trane 3.5 ton straight ac outside compressor unit 4TTR3042A, and indoor air handler unit 4TEC3F42, which replaced an 18-year-old Reem. The new Trane works fine, except for a hum coming from the air handler unit, that's audible in the livingroom when the unit is off (turned off by the automatic temperature control), or with the "heat -off - cool" switch physically turned to "off."
    There was no air handler hum when off, with the old Reem unit replaced, or with other central ac units I've owned in other homes in the past.
    1) Is the hum with the new Trane unit caused by a poorly wired hookup? 2) Is the hum caused by an incompatibility between the air handler and the White Rogers thermostat installed? or 3) Is the hum caused by a poor design in the Trane unit wiring itself, that supplies electricity directly to a transformer, without going through a relay that's controlled by the thermostat?
    Dec 2006
    Middle Tennessee
    if its bothering you, call the installer, maybe they can do something to queit the t-former down
    Exeter, NH
    See... You should have bought a GOODMAN
    That "Hum" you hear could be something serious. Could you "Hum" us a few bars, maybe we could figure out what it’s trying to say... Like the famous line from OZ, "Oil Me"....
    Or maybe the operating transformer is just louse and one turn if the screw will stop it... Thank God you didn’t tell us how much you paid to be annoyed by this "hum"…
    This could never happen on a Goodman unit.
    Dec 2006
    Middle Tennessee
    Quote Originally Posted by heatkits View Post
    what is the hidden message you are trying to send about Goodman?
    Exeter, NH
    Just making a joke...
    I'm a certified Goodman repair center/dealer and have been for 15 years. I find Goodman just a well built and reliable as anything else on the market.
    I take exception to the guys who would have believe Trane is the best... At least Goodman doesn’t whore their product through Home Depot.
    But, they would if they could. Just like any other company.
    Quote Originally Posted by Airmechanical View Post
    I agree. Sounds like the transformer to me too.
    I do belive they did once upon a time w/ EVERSTAR brand
    Quote Originally Posted by cstreet View Post
    If it didn't supply electric directly to the transformer. The stat wouldn't get 24 volts to control anything.
    Just call your contractor.
    Could be a loose mounting screw.
    Or may need an isolator.
