    South Jersey
    Digicool Malfunction.......Hey Doug!
    With all the job change BS, my digicools have been hanging in my garage for 2 1/2 weeks. Went to use them today and the high side read 465, low read 25, without being hooked to anything.
    I zeroed the unit and it froze on 0 psig.........high and low side. Tried turning it on and off a couple of times, no good. Hit it with nitro and hooked it to the vacuum pump, no dice............just sat on zero.
    I gave up on it and threw a pair of analogs on the system to get the job done..............when I got home, I pumped it up with nitro through another manifold and it seems to work perfectly.
    The unit has otherwise preformed flawlessly. Any ideas whats going on?
    mine did something strange like that a couple months ago.
    i changed the battery and all has been good since then...
    South Jersey
    I'll try a new battery.................hopefully that's all the problem is.
    if you need his # e-mail in profile
    South Jersey
    I know where to find him.........
    Looks like the battery may have been the problem..........time will tell.
    Thanks.
