Results 1 to 13 of 26
Thread: R22 phase out-compressors?
07-16-2008, 06:57 PM #1
I know that the equipment will stop being made in 2010, but I am not sure if replacement compressors will still be available and be manufactured. They still make R12 compressors don't they?
There will be a lot of pissed off people if every time a compressor goes out they have to change out their lineset, unit and coil. Money is to be made!
07-16-2008, 07:41 PM #2
- Jul 2008
- 33
You will still be able to get parts for R-22 units after 2010. Expensive they will be.
07-16-2008, 07:55 PM #3
While the price of R-22 will go up on 2010, and the main reason is no new R-22 will be made.
The parts and equipment will still be there for a few years, but its just gonna cost more. And what R-22 that is sold will most likely be stuff that was recycled, once all the virgin stocks are depleted.When you do a job, Always make it easier for the next guy, because you may be the next guy working on it.
07-16-2008, 08:19 PM #4
IN 2010 R22 may go. And R410A may sky rocket as the demand for it doubles.
R22 compressors will still be made, and available for many years yet. And they won't be anymore expensive then an R410A compressor.
I can get R12 compressors for the same basic price as an R134A compressor.
Any contractor that tells you mechanical parts for R22 systems are going to be expensive, is just using scare tatics.
07-16-2008, 08:20 PM #5
- Dec 2007
- MA
- 58
r-22 will be manufactured until 2020, but the amount that is made will be reduced. in 2010 they will stop making equipment with r-22. the price of r-410A is actually coming down right now because the patent recently expired. the price of r-22 will soon exceed the price of r-410A
07-16-2008, 08:37 PM #6
Professional Member*
- Jun 2007
- Round Rock
- 2,920
I would think that the cost to manufacture an R22 vs. R410 compressor will still be very close. Only horse's arse's would try to gouge somebody, risking losing business, most in this industry aren't stupid. You have to take into account that most of the time when a compressor croaks and it isn't in warranty, the unit gets replaced and most compressors will run for a while, its a low percentage that die. And just because you change from 22 to 410 does NOT mean you have to change the lineset.
07-16-2008, 08:40 PM #7
- May 2006
- 281
As several have said R22 compressors will be available. The manufactures have to have compressors ( warranty parts) available until the warranty period is up. It doesn't mean they will be readily available, but they'll be available. Like many HVAC parts, as the demand dwindles supply houses will still carry them, just not as many as they once did. I still keep parts for units that haven't been made since the late 80's and early 90's but that shelf space shrinks every year. Heck I've got NOS parts that haven't been made for years, original control boards, defrost boards, etc etc..
whaaaaa, you let all the smoke out
07-16-2008, 09:05 PM #8
Why couldn't you just use a 410 compressor on 22 ?
Why couldn't you just use a 410 compressor on 22 ?PHM
When faced with the choice between proving that their opinion is correct and changing their mind to fit the evidence - most people get right to work on the proof.
07-16-2008, 09:24 PM #9
Member
- Jul 2008
- Davie, FL
- 211
07-16-2008, 09:52 PM #10
- Jun 2007
- Round Rock
- 2,920
07-16-2008, 10:11 PM #11
- Jul 2006
- Virginia
- 3,744
07-16-2008, 10:31 PM #12
07-16-2008, 10:34 PM #13
Perhaps we can elaborate on this a little. The two refrigerants use a different oil, so you have to either change the lineset or flush the old one with something like R-11. Those flush kits are about 75 bucks now. Linesets are high, but they are scraping high too! Is there some other way that I don't know about?
