Results 14 to 17 of 17
Thread: Quick Fix, or go bananas??
07-16-2008, 08:21 PM #14
Please don't think I want to give you a hard time but... it is not elementary how you measure this and I would like to ask your method. 34% is a big deal after all (I am a homeowner in S.Texas and paying 17 cents/kwh). One of the pitfalls I see is adjusting for weather, average conditions could be different in the before vs. after test periods. It is a rare electricity user who even goes as far as you do.
Myself, I got a 17.5 SEER combo installed at the beginning of summer 2007, and tried to track my own usage. Thought it would be good to attempt to normalize it by KWH per degree-day. My usage was *way* down but so far that I suspect my methodology was not good enough. That summer was actually mild and I think KWH is not linear with respect to degree-days. Still saving a lot of money, just not sure how much until another summer or two goes by.
Best wishes -- Pstu
07-16-2008, 08:25 PM #15
- May 2006
- 281
Are option 1 & 2 still Duel Fuel systems?
If you chose option 2 and its Duel Fuel, make sure you ge the variable speed furnace, or you won't get all the benefits of the 16 seer system.
Regardless of which you choose between option 1 and 2 you'll save money over that 18 year old system.
I've sold several Rheem Duel Fuel setups over the last few months, including 3 16 seer Duel Fuels. For the older generation they like the fact they still get to keep their gas heat, but they like the energy savings they get from the heat pump.
The Eco Friendly younger generation like the benefits of dehumidification, energy savings (gas and electric) and the ozone friendly refrigerant.whaaaaa, you let all the smoke out
07-16-2008, 08:26 PM #16
- Jul 2008
- 4
That brings up another question I had about heat pumps. The unit that needs replacing is/was a heat pump. Only one of the professionals recommended a heat pump in our home as an option. The others said the benefit just wasn't there. When we first moved into the home, I thought the heat pump was an awesome idea. I have only lived in this home for 2 years and I have seen considerable savings on our gas bill during the winter. However, our electric bill was almost as much during the fall and spring as it was in the early summer months. I just kind of thought I was trading one expense for another and it was coming out a wash. Just my opinion, but maybe I need to be convinced otherwise.
So far everyone is leading me in the right direction. I appreciate your time.
07-16-2008, 08:30 PM #17
Member
- May 2007
- Naples, Fl
- 889
The cards are stacked against R22 right or wrong but your personal best option with the current (consumer-contractor-manufactuer) love of R410a is go with the flow. Because there's a chance that in the future someone will look through jaundice colored glasses at your home with an air conditioner that has inefficient, earth destroying R22.
