Results 1 to 13 of 17
    Quick Fix, or go bananas??
    Our compressor went out on our 18 year old Carrier Duel Fuel Heat pump over the 4th of July.
    3 professional quotes later, I am still having a hard time making a decision.
    Option 1: Builders model Carrier 13SEER R22 Compressor/Coil/Furnace
    (This will tap my budget, but I won't need any financing)
    Option 2: Go the the new stuff. Rheem 16SEER 410A Compressor/Coil/Furnace
    with new lines.
    (This goes over my budget, will need to finance somehow, but we do plan on staying in the home for at least 10 years)
    Option 3: One dealer had a used 10SEER Heat Pump compressor that he could swap out with the bad one. The compressor has 1 year left on a warranty, but of course the rest of my unit is vulnerable if things go wrong.
    (initial price is well within my budget)
    One other question. Can you clean your existing lines instead of replacing them if you are going from R22 to 410a??
    Thanks in advance for your time,
    Robot
    Naples, Fl
    you might live long enough to regret gamble #3.
    in mho the correct size refrigerant lines are most important. There are r410a systems 9 and 10 years in operation and the line set wasn't replaced.
    Jun 2007
    Round Rock
    I wouldn't replace the compressor unless you have serious plans to replace everything soon or go into it with your eyes open as to what will happen soon enough. Don't buy more than you can afford is all I tell people.
    Massachusetts
    I replaced my own system this past fall. I pulled out a 10-SEER AC system and replaced it with a 18-SEER Hybrid Heat system. Best money I've ever spent. Yes, I did the job myself, since I own a PHVAC business but that's not the point. Because of my wife allergies, we operate the blower 24/7/365. I've tracked the electrical useage and am averaging a 34% reduction in my electric bill since we fired up the new system. That might not sound like much but over a period of 15-years or the average life of a system, I'll realize a savings just in electric company overpayments of over $7,500! Our house is much more comfortable now with a 2-stage outdoor unit, much better dehumidification and I'm also lowering my greenhouse footprint by using 34% less electricity. In fact, if all the 10-SEER and lower rated units were replaced with 18-20 SEER units, the electric utilities could breathe easier for a long, long time. As it stands in our area, they electric usage was within 500 GW of capacity during a hot spell last summer. Now our electric utilities are offering $900 rebates for replacement of 10-SEER or less AC/HP units, for obvious reasons. So, as you can see, my recommendation is to get the most energy efficient system you can. You'll gain in comfort physically and your monthly electric bill will be more comfortable too. Whether R-410A or R-22 is your choice (if you can find a high efficiency R-22 system) but doing a quick flush on the old lines and reusing them, if properly sized for R-410A, is not a problem.
    Throw option 3 out the window. That falls in the I told you so category. Spend the money, get a good system with as high seer rating as you can afford. You won't regret it. You definitely get what you pay for in this situation.
    Quote Originally Posted by Robot Robot View Post
    with new lines.
    Robot
    My suggestion is possibly get a couple of more quotes, heck most are free.
    And yes the exsisting lines can be used if they are of the correct size required by the 410a systems specs. It just requires flushing them out with nitrogen and using some RX-11.
    But in my opinion I would go with a R-410a system, yes the equipment is a little more costly up front. But in the long term it could be more cost effective over a R-22 system, especially since the price of R-22 will be going up.
    When you do a job, Always make it easier for the next guy, because you may be the next guy working on it.
    So focusing on option 1 and 2.
    What are the real pros/cons to staying with an R22 13SEER system?
    What are the real pros/cons to changing over to a 410a 16SEER system?
    Is it an irrelevant concern of mine to focus on the coolant?
    I really appreciate your time,
    Robot
    Quote Originally Posted by MichaelPaladin View Post
    What is the correct size of the line? Is it more cost effective from a labor standpoint to flush the existing lines if they meet the requirements or is it just easier to run a new line? Only one of the three estimates even mentioned being able to use the same line if upgrading to 410a.
    Thumbs up
    R-22 is only going to get more and more expensive as they phase it out. If you get a leak after the warranty runs out, it will cost an arm and a leg and maybe more. 410 is the present and future. It's economically and environmently friendly. A higher seer unit will save you on utilities. if you pay $4500 for a cheap r-22 system, you get a new air conditioner that cools just fine. If you get a $6000 410A system, you get an air conditioner that pays for itself over the life of the equipment. Once you cross sides to a variable speed blower motor, you'll never go back. They are wonderful. Short story, 410 15 + seer is the way to go.
    Naples, Fl
    make yourself a little decision matrix such as
    Dealer, dealer, dealer, dealer then make your choice; as suggested talk to another dealer or two. some folks get too many bids and get confused then end up not getting what they thought because they mix their flavors.
    Idaho
    I myself would go with a new unit rather than gamble on a used compressor.
    Unless the cost of the used compressor is free.
    The higher the seer the more efficient, however it will probably take a little more time to pay off with its higher cost. So, the next thing you should consider is how long do you plan to live in that house?
    If you are going to sell it in, say, 5 years, will you still be paying on the loan.
    but, The better the equipment the more attractive the sale of the house but it doesn't usually bring up the homes value.
    So everything is a trade off one advantage for another.
    Getting more bids on the issue is never a bad idea also.
    But really, consider new equipment the only way to go in this situation and you will save yourself future expenses and headaches.
    Also, ask about heat pump options- fuel prices these days- running a furnace all winter is expensive.
    Never take life seriously. Nobody gets out alive anyway.
    The manufacture of new R-22 stops on Dec 31 2009, so the price of this will go up considerably. You think gasoline is high now, its feasible that R-22 could hit $50-80 per pound and maybe higher. If you happen to get a leak or other problem the it could get costly for the repair.
    The con of 410a, the equipment cost more right now.
    The Pro, The system will be more energy effecient over the long term. And if you need a repair done that requires replacing the refrigerant, the 410a will be cheaper than R-22.
    Nope its a valid question, and your just looking to get all the available information to make a informed decision.
    As for line size, that really depends on what specs are for the size of the unit.
    Robot
    Idaho
    It is my understanding that you absolutely do not want to risk mixing r-22 with r-410a. This is a potential for many future problems, just one being a failed compressor. Even flushing lines does not guarantee every bit is out. The oils are very difficult to completely clean out.
    And how would one know if a line is clean inside?
