Results 1 to 13 of 14
Thread: taking wet bulb
    Mar 2006
    Delaware,United States
    taking wet bulb
    what do you guys use to take wetbulb temps I'm looking to upgrading my cps piece.
    Nov 2000
    Upstate, SC
    Testo H2 is what I and other techs use.
    Mar 2006
    wet bulb
    Thank you
    Toledo, Ohio, United States
    Twilli uses amprobe
    No Heat No Cool You need Action Fast
    in a house, Appomattox, Va.
    Cooper- the humidity probe will fit a 1/4" hole so I can take static and temp readings at units easily.
    Col 3:23
    maui
    Have you guys noticed when you take your meter from the truck to the house it takes forever to give you an accurate reading? I have the testo H2, fluke 971, and the amprobe. my favorite is the testo but they are all accurate within a half degree. Just wondering what you guys do to speed up the process from the shock to the meter from going from a 120 degree truck to a cooler house..
    Jul 2005
    Tulsa
    Extech humidity/temp digital meter
    Bacharach Sling Psychrometer with wet/dry bulb
    testo H2 and supco digitals both work great for checking duct temps wb,db,rh
    I use my Alnor ebt-721 temp/humidity probe. has a 3' retractable probe, works very well. good luck
    AIRFLOW IS CRITICAL
    Jun 2008
    Michigan
    Quote Originally Posted by ryand View Post
    I usually pop it in the return first thing...because the unit should run a good 10 mins before making any adjustments anyways...
    cooper sh77
    Syracuse, NY
    Amprobe here
    Life is to short to sweat the little thing in life!
    Jan 2006
    Cincinnati, OH
    I use the Cooper SRH77A. It is traceable to NIST standards.
