    scotsman cme 456
    diagnostic lite....refrigeration on solid
    reset....freeze drops twice....
    third cycle...float drops.....instead of harvest....pump comes back on fills reservoir ...then locks out
    105 deg inlet air.......
    will long freeze cycle cause solid refr lite lock out....tech support didn't exactly answer the ?????????????
    then bin full light came on....only 10" ice in bin
    I'm certain I hav e more than one problem.
    Denver, CO
    Have you checked your bin eyes? when the ice drops you should see the bin light flash
    bin light was last thing to signal today.
    they had a 15 ton unit down.....I decided to get their cooling working and left the ice machine for tomorrow.
    I'll pull the eyes when I get back
    yesterday it had 2 flash refrigeration code. reset ran 20 hrs. don't know if they had used ice from machine, but there wasn't as much as I thought there should be.
    then today run s then solid refrig and later bin full
    Scottsdale,AZ
    long freeze or low discharge temp will cause solid refrigeration diagnostic according to Scotsman
