Results 1 to 13 of 19
    soldering stainless steel components to copper, what solder?
    What is the silver solder that is used to solder SS tubing to copper tubing, isnt there a percentage of silver in that particular solder that has the best adhesion qualities, like 50% percent silver solder. What do you guys recommend?
    Anytown USA
    i use 45% with the correct brazing flux.
    South Carolina
    ditto
    Yup same here,
    45% with Brazinf Flux...don't forget to put a put a "Flux Capacitor" after you're done!
    burlington county n.j.
    good timing for this question...
    i have to make a stainless pan tommorow and braze a copper drain line into it......
    florida
    Quote Originally Posted by y7turbo View Post
    Ditto.
    Educational forums are open.
    the white paste?
    florida
    Quote Originally Posted by t527ed View Post
    the white paste?
    Yep that's the one.
    thanks, didn't know of any other flux for silver.
    Anytown USA
    the white paste?
    yeah i forgot the name, its stay something lol.
    Stay-Silv Brazing Flux from Harris
    Apr 2008
    On the roof
    paste the joint and use blue rod or some 45
    If you didn't do it right the first time it probably makes sense that your here asking the right way to do it now
    45 and the white past flowed like hot butter...........
