Results 1 to 9 of 9
    line freezing up
    the main line going from my outside unit to the unit under my house is freezing up! I have changed the filter and just put a fan under the house to help evaporate the standing water. Can someone please help? Why is the line freezing up? What else can I do?
    Call a service tech before it damages your compressor and cost you a fortune for a new compressor.
    You changed your filter, that about all the more you can do.
    I'm guessing its been a few years since you had a clean and tune done to it.
    actually i moved in a few months ago. so i dont know when it was checked last. i called a service guy and he said it was most likely low on free-on.
    Jun 2008
    The service pro will adjust the refrigerant level to the proper level, if necessary. If that is all he finds, make sure to ask him why it is low and get that addressed.
    Minnesota
    how dirty was the filter?
    White Bear Township, Minnesota
    www.summitheating.com
    Nov 2007
    Quote Originally Posted by lascougar View Post
    locate a leak because unfortunately this freon isnt free
    here i am
    do u still have air blowing out of the vents
    i do have air blowing thu but ive turned it off till he comes and checks it out. and the filter was horrible. i bought 3 so i wouldnt run out.
    here i am
    if u cant find a leak in ur system and the charge is good, then u have air flow problems make sure u have all ur vents open
