Results 14 to 21 of 21
Thread: BACNet Router LON to MS/TP
07-17-2008, 04:24 PM #14
Banned
- Mar 2006
- 3,641
Is this what you want?
EDIT
ops thats ethernet/IP
08-29-2008, 03:31 AM #15
- Apr 2008
- Nevada
- 58
FYI
I have set this up using a JACE 6 with a LON card and driver, A BACnet server driver, and a fair amount of programming in Tridium AX. In the end it was well worth the effort. The project involved Trane Intelli Pack rooftops with LCI-I cards, Delta VAV controllers, and a ORCA View front end. Despite Trane's best efforts to be difficult, I still created a seamless integration.
Best Regards,
boardsmoker
10-22-2008, 05:40 PM #16
New Guest
- Oct 2008
- UK
- 1
Freddy_B,
The device you refer to is the one PicNik already has, and converts the BACnet on LON signal into a BACnet on IP (not to be confused with BACnet Ethernet which I understand to be significantly different).
PicNik,
I understand Siemens US are looking at a BACnet / MSTP PX based device in the future, and there may therefore be a Siemens solution to your problem. Don't hold your breath though, not sure when. In the meantime I will asl on the Euro DAS site to see if anyone there knows of a device.
10-22-2008, 05:54 PM #17
- Nov 2005
- Shreveport, Louisiana
- 2,240
10-22-2008, 05:59 PM #18
10-22-2008, 06:03 PM #19
Permanently Removed
- May 2002
- 9,564
LON is a full 7 layer OSI so it can transfer bacnet.
Therefore you can have bacnet/IP, bacnet/MSTP and even bacnet/LON. What you can't have is LON/bacnet, because bacnet does not have this capability. Bacnet is not a full 7 layer OSI implementation.
And yes as somebody suggested, Loytec can transfer those packets. So can others. However, that doesn't really help you.
10-22-2008, 06:21 PM #20
10-23-2008, 02:21 AM #21
I suppose with Siemens Europe the only company doing BACNet/LON and their headend unable to scan a BACNet network for other devices, it makes it almost proprietory
Anyway, thanks guys. I will have to wait for siemens to produce their own. I won't hold my breath as its unlikely they'll make one till they have an MS/TP device to sell (why promote interoperability!!!)-----------------------------------------------------
Don't be a stupid dwarf. It's not big and it's not clever!
