Results 1 to 7 of 7
    Can a flexible 'plastic' ac duct take a head pump?
    We currently have a flexible 'plastic' duct work for the ac. Can we use a heat pump with that kind of duct?
    Lincoln, Nebraska
    Are you talking flex duct? Not sure what kind of ducts you mean. Can you post pictures?
    Its a good Life!
    I do not have pictures but yes it is flex duct. thanks
    Dallas & Longview, TX
    Heat pump is not as hot as a gas furnace and gas works with flex. Why do you ask? Does your contractor have a different opinion?
    Do not have digital camera but the duct is big plastic round 2' with metal rings that holds the trunk.
    Lincoln, Nebraska
    As stated a heat pump has lower discharge temperatures than a gas furnace or electric heat so you should be alright if sized properly. Do you have air conditioning now or just heat?
    Its a good Life!
    Have forced air heat through metal duct. Have a separate ac that uses flex ducting in the attic. Glad it works. thanks
