Results 1 to 8 of 8
    In the sticks,Northern Idaho
    Thumbs down I think I'll buy three......
    Wonder how many DIY'S will buy these.
    http://www.harborfreight.com/cpi/cta...emnumber=98076
    "The trouble with the world is the stupid are cocksure and the intelligent full of doubt" -Bertrand Russell
    From the add: "Increase the life of your air conditioning or refrigeration system with this vacuum pump, which removes moisture from condensable gas.
    WTF?
    WTF?
    TeddyBear must own stock in HarborFreight.
    May 2008
    Spfld, IL
    you should have posted it in "Residential". ((((sarcasm intended))))
    May 2008
    Clovis/Fresno CA
    maybe
    someone will then i can go and charge them for being a Dumba**
    wi
    what do you guys use for vacuum pump cfm wise
    we use 10cfm for rack work
    by the way that cr#p pump is only a single stage
    Bay Area, CA
    WTF?
    Thats the most awesome vacuum pump ever
    Global Warming or: None like it hot
    No pleasure, no rapture, no exquisite sin greater... than central air. -Dogma
    Quote Originally Posted by wildtech View Post
    depends on the size of the equipment i do mostly resi work and light commercial. 2.5cfm is really all i need and use. i have a 5cfm pump as well that i leave on systems when i have to do extra moisture removal, like overnight and such.
