Results 1 to 13 of 25
    Evergreen Park (Chicago)
    AC Coolant Line Loops
    The far AC unit in the photos (6 ton, I believe) makes 5 coolant line u-turns under this deck before it heads up the wall to the 3rd floor. What's the reason?
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	8131   Click image for larger version.
    MN
    Now that's different. I guess they had some extra copper laying around. Maybe thought that they needed a minimum line length. no idea.
    You can't fix stupid
    Dec 2006
    Dallas
    Bonus loop for copper thieves. Pipe sweating exercise at your expense.
    Certainly doesn't add to flow performance.
    Lancaster PA
    Maybe its a secondary condener loop to make up for the poor air flow the steps create.
    Dec 2006
    Dallas
    Anti-SEER Reactor Cell
    DC Metro area
    Maybe their idea of an oil trap?
    Jun 2008
    Sacramento
    Another Q
    Is there any conceivable reason to install the units under the STAIRS (lowest overhead, least airflow?) instead of under the deck (i.e. 4' to the right of the chosen location)?
    Was this a builder install, or "after market"?
    Jun 2008
    Morgantown, WV
    Looks like the Rube Goldberg to an overcharged system fix. Just make a giant suction line with a bunch of turbulence and you've got a not so cheap accumulator!
    Denver, CO
    Huh thats weird sure don't look like a precharged lineset. looks like someone to a lot of time to sweat 90's in there. Looks like a waist of time and money, I wonder what their reasoning behind that is.
    Apr 2008
    On the roof
    Maybe their intent was to cool off the deck kind of like using Wirsbo Pex for heating underneath a floor.
    Maybe they weren't sure where the home owner would want the unit so they were giving them options and finally settled on the corner behind the stairs.
    Maybe a journeyman left his overzealious apprentice to do the hook up outside while he did the lines inside.
    Maybe they read in the directions that the unit was charged for a 50 ft line and the only went in to the house 10 ft.
    Maybe the installer got paid by the ft.
    Just a few ideas
    If you didn't do it right the first time it probably makes sense that your here asking the right way to do it now
    Thanks.
    The original coolant line had been cut and replaced with this set up. I'm a home inspector and I told my client that this was puzzling.
    I have seen this many times. It is usually done to allow the suction line to pick up some heat from the ambinet air to give the deck dwellers some relief. The little cooling effect actually will cause the temp of the air rising through the boards to provide some cooling during high deck occupancy loads. In addition, this allows the installer to grossly oversize the systems. The compressor will not experience problems usually associated with gross oversizing, due to the added load of the outdoor air. As far as installing the condensers under the stairs.....where else would you put them so that you didnt take yup valuable square footage of patio space?
    Lancaster PA
    Usually works better if the lines aren't insulated.
