Results 1 to 7 of 7
Thread: Roto locks
    Aug 2001
    Roto locks
    The other day on a service call I located a leak on the suction side roto lock at the comp. Today I tryed a new seal but there is still a leak on the fitting that is mounted on the copper pipe. Are these brazed in or soldered? This is a Trane cond unit 7 year old one.
    Virginia
    brazed ,i would replace the roto lock and make sure the compressor does not have a vibration
    Aug 2001
    Thanks I will order a new roto lock and check it over. I have never run into this befor.
    burlington county n.j.
    leaking on braze joint or threads???
    might just need a bigger wrench.......
    Alabama
    cracked solder
    I've fixed e few leaking at the solder. You gotta use 45% with flux!!
    Aug 2001
    Yes it is leaking at brazed joint. So no silfos just solder the joint in?
    Alabama
    I use Safety-Silv 45. Flux coated silver brazing alloy rod
