Thread: Oil Leak
    Jan 2014
    Oil Leak
    My home central air conditioning quit the other day.
    Upon inspection, I saw a small amount of oil on top of the compressor and around the bottom also.
    Repair turned out to be replacing the start capacitor, not the compressor. The unit runs fine now.
    Could oil have leaked from the compressor fan and dripped down onto the compressor ?
    I did not know that these motors had an oil reservoir, I thought they had oil impregnated bushings.
    Due to the oil leak, should I replace the fan motor ?
    Thanks for your help
    Jan 2014
    New England/Florida
    Fan motors have run capacitor , compressor uses run capacitor unless you have a start kit, then that part consists of a start capacitor. If it was the start capacitor that blew that may be the problem as they have some sort of residue inside the capacitor. The motor could be leaking onto the compressor top. Some older unit fan motors had two oil cups , each side of the motor. You should call for service to have them check your system.
    Jan 2014
    My mistake- The capacitor they replaced was a "Run" capacitor.
    What would cause the motor to leak oil ? Overheating ?
    Would you suggest replacing fan motor since this leak happened ?
    Cleveland, OH
    It could've leaked from the condenser fan motor. Sometimes they leak if someone oils it too much, sometimes the sealed bearing begins to leak. The oil also could've come from the bad run capacitor. They are oil filled, and I've seen them burst with a lot of force and spray oil everywhere.
    If the motor isn't making noise or otherwise acting up I'd leave it alone.
    "We always fix it right the second time".
    All posts are strictly my opinions and not those of my employer. I cannot make statements on behalf of my employer.
    All advice posted by me is for educational purposes only, HVAC repairs should only be conducted by trained & qualified people.
    Mar 2009
    Mount Holly, NC
    Agreed!
    Quote Originally Posted by dougfamous View Post
    The TRUE highest cost system is the system not installed properly...
    Find a HVAC-Talk Contractor by clicking here
    Click below to BECOME a pro member
    https://hvac-talk.com/vbb/forumdispl...ip-Information
    Do you go to a boat repairman with a sinking boat, and tell him to put in a bigger motor when he tells you to fix the holes?
    I am yourmrfixit
    Cincinnati, Oh
    It's not unusual to have water in an outdoor unit due to condensation.
    Are you sure it's oil, and not water?
    "Just get it done son."
    Dad adjusted
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
