Results 14 to 24 of 24
    here i am
    Quote Originally Posted by richmod View Post
    My plenum is sheet metal and is NOT insulated - should it be? Only the ductwork is insulated.
    the plenum is located in non-conditioned space it has to be insulated
    Alabama
    Quote Originally Posted by cnpro18 View Post
    What is the temp. diff between the supply and the return. Coil could be too cold.
    The dude has a uninsulated plenum in a crawl, its gonna sweat regardless of coil temp.
    Don't know - how would I measure it?
    Of coil is too cold, can that be adjusted on the AHU?
    Quote Originally Posted by thandar56 View Post
    Is that a requirement? If so, I'll be sure to advise the tech as such.
    Angry
    Quote Originally Posted by superd77 View Post
    Any uninsulated plenum in a non conditioned space is going to be creating a small flood, not just a little condensation. Sounds like it may be internally insulated and Mr. homeowner doesn't know any better. I've seen plenums sweat in conditioned spaces if coil is too cold due to some other problem.
    You would need to call a tech to come check it out.
    Alabama
    If its cooling fine, chances are he's got a humid crawl.
    And yes , it probably is a duct lined plenum with a few air leaks.
    It's not just a little condensation - the whole plenum is covered with condensation, and there is actually a small pool of water under it now, though not a flood.
    I'm in North Carolina, so yep - pretty humid down there right now. And yes - it is duct lined - 2 zone ducts, bypass duct, and return duct.
    Tech's coming next week - thanks for all the info and opinions.
    Alabama
    Dude, you are totally welcome!!
    Apr 2006
    Original Poster
    My plenum is in the attic. It is insulated in the inside with insulation. I don't notice condensation all the time, just some times. Should I be concerned or does this just happen sometimes?
Comfortech365 Virtual Event
