Results 1 to 13 of 24
    Apr 2006
    Condensation On Plenum
    Is it normal for condensation to be on the outside of plenum in the attic. It was over 100 degrees in the attic and there was slight condenation on the output side of the blower.
    Alabama
    You mat have air leaks. Or missing insulation on inside of air handler. Only seen a couple sweat in attics. Both were foamed attics.
    How about on the plenum in a crawl space? Our new system has slot of condensation on the plenum. Is that normal?
    Alabama
    Yep!!
    Do you have a good moisture barrier??
    Does rain water get under the house???
    Is the crawl damp???
    Quote Originally Posted by superd77 View Post
    Yes, no, and not really.
    Maybe I'm dense, but just making sure - it is normal, correct?
    Upstate SC
    Is it sweating over most of the plenum, or just in a few locations? My old plenum portions (sheet metal, paper wrapped insulation) in the crawl space never sweats except where the insualtion is torn or loose. The new round flex duct the installer used to replace a portion of the plenum sweats over most of it. I have a vented crawl space, with a pretty decent moisture barrier on the ground.
    Alabama
    Is your crawlspace vented??
    Quote Originally Posted by richmod View Post
    Ducts sweat in crawlspaces in the south. May need to and insulation.
    May 2008
    CHICAGO IL.
    To Humid In Attic Call Technician To Look At Duct Work
    What is the temp. diff between the supply and the return. Coil could be too cold.
    Alabama
    Quote Originally Posted by cnpro18 View Post
    The dude has a uninsulated plenum in a crawl, its gonna sweat regardless of coil temp.
    Angry
    Any uninsulated plenum in a non conditioned space is going to be creating a small flood, not just a little condensation. Sounds like it may be internally insulated and Mr. homeowner doesn't know any better. I've seen plenums sweat in conditioned spaces if coil is too cold due to some other problem.
    It's not just a little condensation - the whole plenum is covered with condensation, and there is actually a small pool of water under it now, though not a flood.
    Don't know - how would I measure it?
    Of coil is too cold, can that be adjusted on the AHU?
