Results 1 to 13 of 15
    Thermostat ? for 2 stage system
    Posted questions about our A/C system over the past few weeks and another question crossed my mind as I was doing some more research.
    Since we have a 2 stage system trane xl16i, do we need a thermostat that has a 2 stage option? What is the purpose/advantage of a thermostat with a setting for 2 stage cooling? Our current thermostat does not have a 2 stage option
    whats the question, the suspense is killing me.
    Arizona
    Quote Originally Posted by aintitfun View Post
    Jun 2007
    Round Rock
    It's kinda a self answering question. If you only have a 1 stage thermostat and a 2 stage a/c. It can only run 1 stage of the system. So 1 entire stage will never be used, which is a waste of the money you spent on it. If you're not gonna buy the thermostat, why did you buy the equipment. The heater will switch automatically unless you cut the jumper on the board. You will either run on "high" or "low" capacity depending on how it is wired.
    Dec 2006
    Northern VA
    Quote Originally Posted by bmathews View Post
    OR
    Both stages are coming on at the same time and running at full capacity all the time.
    You should be asking my installer that ?....I'm doing all this damn research because my brand new ac is not working properly. thanks for the info. I'm trying to figure out why THEY didn't install a 2 stage t-stat. don't need the heat info, as we have baseboard hot water..
    No YOU should be asking your installer that.
    I though they were spelled out..but i'll make it easier
    1. do we need a thermostat that has a 2 stage option?
    2. What is the purpose/advantage of a thermostat with a setting for 2 stage cooling?
    Arizona
    You may have a 2 stage thermostat, but it is not set up correctly. Without a 2 stage thermostat your 2 stage system will only run on 1 stage, you paid for two.
    A complete waste of money to get a 2 stage A/C, and only running it on a single stage stat.
    What is the brand and model number of your stat.
    Your unit is more than likely mis-wired. You have a zoning panel and that will control your stages if wired correctly. From your previouse posts it is not wired correctly.
    it is a honeywell pro 4000. The system does have a zone panel...does that mean we don't need the 2 stage tstat? Or, will the 2 stage tstat provide better control even with the zone panel?
    Lastly, I've seen that honeywell has a stat that appears to allow you program fan speed...will this help us solve the problems?
    thanks in advance for all your time and suggestions over the past 2 weeks.
