Page 3 of 5 FirstFirst 12345 LastLast
Results 27 to 39 of 54
  1. #27
    I think your missing a wire to the furnace.
    Let me guess. Is it the one for dehumidification and giving IAQ total control of VS blower?
  2. #28
    I give up. Which one is it? Thanks again for all your input beenthere. My tech sends his thanks, too.
  3. #29
    I may be thinking of the wrong model furnace.
    But doesn't the furnace have an O terminal.
  4. #30
    Oh, and you don't have the IAQ listed as wired to control blower speed for dehumidification.
  5. #31
    The furnace does have an "O" terminal on its board, but the manual doesn't show it connected to anything. What is it supposed to go to?
  6. #32
    Correct. The dehum terminal on the IAQ is not connected to the furnace. We couldn't quite be sure how to wire it and the tech didn't want to cut the jumper and then not have it work right at all.
    Is it just one wire from Dehum on the EIM to the Dehum terminal on the furnace and cut the jumper? It seems like there should be a 2nd wire connection.
  7. #33
    Dec 2006
    Middle Tennessee
    Quote Originally Posted by badtlc View Post
    O needs to be hooked up
    that's why it's not going to the ramping profile!
    i won't get more technical than that in this forum!
    have your technician e-mail me
  8. #34
    Technically not allowed to give the answer to that.
    But, think of it this way. How is the furnace suppose to know if its running in HP heating mode, or cooling mode.
  9. #35
    Dec 2006
    Middle Tennessee
    yes 1 wire!
  10. #36
    The IAQ has instructions that will tell the tech what wire hooks where on the EIM.
    Then he has to READ the furnace instructions very carefully.
  11. #37
    Quote Originally Posted by Airmechanical View Post
    Odd, the ramping profile is working just fine..
  12. #38
    Well, the furnace is connected to the Y1 and Y2 terminals. The blower shouldn't care if Y1 or Y2 is in heating or cooling as long as the W1 and W2 terminals aren't receiving a signal. But, I guess having the O terminal connected does add another layer of protection to prevent the aux heat from coming on while the HP is in cool mode.
  13. #39
    The blower doesn't do a slow ramp up in heating mode.
    It has to be told if its in HP heating, or HP cooling mode.
    You said you have a HP.
    So the O terminal plays an important part in the furnaces blower control operation.
    Your tech needs to read and study the wiring diagrams for both the furnace, and IAQ.
