Results 14 to 26 of 54
07-14-2008, 08:30 AM #14
- Jul 2008
- 550
Jumper for Dehumidification? I decided not to set it up for that. My house only has problems when the fan continuously runs.
The jumpers set the ramping profiler. How would the IAQ override that? And right now I think I'm stuck with it until they get the "W2" connected to the furnace. Right now I have to set it up as a single stage furnace because the W2 terminal isn't connected. Could this be part of the problem?
07-14-2008, 08:31 AM #15
- Jul 2008
- 550
07-14-2008, 08:33 AM #16
- Jul 2008
- 550
07-14-2008, 08:35 AM #17
- Jul 2008
- 550
07-14-2008, 08:37 AM #18
- Jul 2008
- 550
Sorry for the multiple short timeframe posts, but I need to correct my original post. The fan is actually running at 50% when the compressor is off. It goes through the proper ramping profile until the call for cooling ends, then goes back to 50%. It is acting exactly like it should for the "ON" setting, not the "AUTO" setting which I have selected.
07-14-2008, 08:41 AM #19
You set the air flow to the CFM you need.
Then their is a jumper that gets clipped on the furnace control board.
And then the IAQ wires up to the dehum terminal on the furnace control board.
When the IAQ sends a signal to the dehum terminal, the blower will slow down.
07-14-2008, 08:41 AM #20
07-14-2008, 08:43 AM #21
Miswired, wires touching that shouldn't be.
Or a bad IAQ.
07-14-2008, 09:23 AM #22
- Jul 2008
- 550
I'll go through and double check all terminal connections for touching wires or wrongly inserted wires. Thanks again for all your help beenthere. I can't thank you enough.
07-14-2008, 09:51 AM #23
- Jul 2008
- 550
beenthere,
On the IAQ, is "CoolOn" supposed to always be showing next to the set point temperature? Or is the CoolOn only supposed to be showing when the comrpessor is running? Right now, that is always showing even when the compressor is off.
07-14-2008, 09:58 AM #24
"Cool On" should only show when it is running the outdoor unit in the cooling mode.
07-15-2008, 08:12 AM #25
- Jul 2008
- 550
OK, here is the wiring. I hope everyone can understand my feable attempt and illustrating it.
EIM----color-----Furnace
aux----white-----W1
aux2---brown-----W2
Y2-----yellow-----Y
Y------orange-----YLO
G------green------G
R------red--------R
C------blue-------C
EIM-----color to heatpump (I can't tell what they are connected to@HP)
R----red
C----brown
O/B----orange
Y-----yellow
Y2----blue
Aux---white
Does that make sense?
07-15-2008, 08:52 AM #26
I think your missing a wire to the furnace.
