Page 1 of 5 12345 LastLast
Results 1 to 13 of 54
    VisionPRO IAQ still annoying me......
    My new system is working fine. Everything cools great. Everything is wired right. I have had a tech out here 3 times to make sure. Here is the problem.
    When my VisionPRO IAQ says "cooling on, following schedule" and the fan mode is set to "AUTO" the compressor will cycle on and off as needed but the fan will run continuously at 100% instead of going through the ramping profiles. If I turn the cooling set point up above the the current indoor temp, the system shuts off completely, like it is supposed to. When the cooling mode kicks on, it goes through the proper ramping modes like it should. I have double checked all my schedule settings and no time periods have fan set to "ON" instead of "AUTO." I could really use some advice.
    Amana ASZ16 heat pump
    Amana AMV8 furnace
    Fort Worth, TX
    You say it's "wired right"...unless you post some pics of how the thing is wired, it's a tough call to make from here. It's either a wiring issue - still - or it's a configuration issue. Ask your installer to send a different tech, if they haven't done so already. Sometimes a fresh pair of eyes is all that is needed.
    Different techs have been out already. I have the installation wiring diagrams for all components. I have double checked and traced them myself. I am an Electrical Engineer by trade and education. Needless to say, tracing wiring diagrams isn't beyond my abilities.
    The system operates correctly outside of the thermostat. If it was a furnace/blower problem, it wouldn't shut off when the thermostat set point is raised.
    Jun 2008
    NE Illinois
    How often does it cycle on and off?
    Is your CPH set high not allowing it to turn off long enough?
    Just some thoughts.
    Quote Originally Posted by EmilG View Post
    Just some thoughts.
    I haven't had much time to check. I didn't realize exactly what was happening for sure until recently. And, I couldn't tell when the compressor was cycling off because the fan wasn't turning off. I was assuming (falsely) that the compressor had been running all the time the fan was on. I'll try and keep track but it will be tough.
    The CPH is set to 3.
    Dec 2006
    Middle Tennessee
    he said the "E" word (Engineer)
    get out the popcorn, it's gonna get good
    Maybe they didn't clip the jumper.
    Shouldn't be using the ramp profile if you have the IAQ.
    Dec 2006
    Middle Tennessee
    yes you should, for a colder coil on start-up
    and for extra efficiency on compressor off cycle during blower ramp down
    Jul 2001
    Gold Coast of Connecticut
    Why not use the output to the v/s blower tap.
    Aire Serv of SW Connecticut- Gas heat, dual fuel and central a/c systems installed and serviced
    Jun 2008
    va
    You need a white-rogers 1f89-211......no more problems then.
    Variable speed fan wiring questions...
    oops - wrong thread.
    Surrey BC
    have you checked the dip swith settings on the furnace/air handler?
    Quote Originally Posted by Airmechanical View Post
    On the standard ramp up profile, the first 30 seconds are at 50%.
    Same as the slow ramp profile.
    When its 90° outside, you don't want to be waiting 7 1/2 minutes for it to go to full speed since the humidity is already down.
    Let the the IAQ control the blower, without the slow ramp profile. It will improve overall operation.
