Results 14 to 21 of 21
    that is awesome!!!!
    i helped my buddy put twins on his mustand a couple months ago
    haven't been able to get dyno numbers on it yet, cannot keep it from spinning on the rollers so far the highest numbers have been 942ish
    In a van down by the river.
    Haven't posted in a while (been working). Just as well get caught-up and start here.
    I've already out-grown the conservative twins install. I've since added much larger 6x0.016" EDMed fuel injectors. With that, I was way over fueled. I added a Hamilton cam and custom Hellman intercooler in an effort to get more air through the engine and make best use of the additional fuel. As such, I'm down to 13.03 in the quarter (@ 6400lbs). The last dyno run presented with 447HP-822ft/lbs to the ground.
    Modding the VE injection pump now has me over fueled again. So I'm replacing the dinky HX35/Hybrid secondary with a custom S300 (62/65/14) effectively doubling the volume of charge-air over the original twin mess. (Keep in mind, I'll still be conservative as compared to many of the later Dodge/Cummins trucks at the track but then again, I'm also 1000 ~ 1500lbs lighter too).
    Looking forward to a new racing season.
    Y'all been doing alright?
    RTFM
    Jul 2005
    Tulsa
    here's my buddy's 97 12v stock turbo'd, stock housing 12V. these 12v cummins can be turned up at very low cost for HUGE gains without reliability or mileage loss.
    97 Dodge 2500 5spd 411.2 994.9
    WOW! I forgot about this thread.
    I've goofed around under the hood such that the ET's down a little. Not bad for a 6400# cinder-block on 33"s. (I'm still small-fry as these things go).
    Upgraded a bunch of the charge-air stuff resulting in a little more bottom-end torque. Bigger secondary turbo, IC, cam, etc. All of which help better burn the existing fuel supplied.
    Enough that I've managed to twist the intermediate shaft in two and most recently stripped the spines of the input-shaft out of the front clutch's hub.
    Oops.
    Gonna have to beef it up more to handle the next level.
    Anybody running a hopped-up diesel work truck?
    RTFM
    Jul 2005
    Tulsa
    recently put in a ceramic button clutch in my 96 12v cummins
    NO slip ... a pita to drive .. but I like it
    purchased a big ole backhoe with a 140hp Detroit Diesel 2 cycle .... so yanked 25k+ lbs last week
    May 2010
    So, I have a 2010 dodge ctd. I want to make it scream. Any suggestions on what upgrades I should do? I know I should go to the ctd forums for this info but thought I would get some suggestions here.
    Quote Originally Posted by ZeroTolerance View Post
    Dunno, you've got one of them weird-quiet too-many-valvers.
    Try here ~ http://www.dieseltruckresource.com/dev/index.php
    RTFM
    May 2010
    Ya, it is quiet. The one thing I dont like about it is people ask, "Is that a diesel?"
