    Jun 2007
    Zoned system - layman
    I've read that you shouldn't buy a HVAC system that is too large for your house.
    But, if you have a zoned system, and you turn off the zone for one floor in a three story house, doesn't that result in the same problem--two large a system for the remaining floors?
    Thanks,
    toddmanqa
    Illinois
    The short answer is no...if designed properly.
    Someone will be along shortly to go more in depth if you desire...but wifey says I gotta go to the grocery store right now
    Dec 2006
    Middle Tennessee
    most zone systems incorporate a bypass damper, as well as a discharge air temp. sensor
    when set-up properly the system will deliver proper CFM
    as well as having overcooling or overheating protection
