    determine piston size?
    Hi, hope someone can help me. I'm replacing a 3 ton york air handler with a 3 ton goodman (m#aruf 363616). The heat pump is a 3 ton Tempstar(m#ch9536). There is a piston kit chart included but I don't see Tempstar model number anywhere. Can someone tell me if i can use the piston provided with the airhandler, or may i need a different size? any feedback would be greatly appreciated!
    Thats because they are not matching units.
    There is not piston match to that combination.
    Hmm
    what worked be for,is a good starting point
