Results 1 to 13 of 15
    Advice on a Recovery Unit
    Hello.
    I was wondering if anyone could supply information or an opinion on the Bacharach Stinger 2000 or the PROMAX RG5410 recovery unit. I expect to only use it occasionally, so I'd appreciate any input that you can provide about which unit to get, or would it be better to go with the Appion G5 or the INFICON Vortex. If you have one would you recommend it? They are all in the JS flyer and seem to be priced OK. I will be doing basic residential AC /HP and I'm looking to to move into all climate air source heat pump systems before too long. Any guidance you can provide is appreciated. I haven't done any real refrigeration work since before the Montreal Protocols, so I'd say I'm due for some new tools!
    Thanks.
    Greg
    manitowoc wisconsin
    I put the promax on my truck though a beating & it is still going.The guys that had apion or inficon had them rebuilt already & they are years newer.
    Take your time & do it right!
    Annapolis, MD: ragboat capitol of the world
    I've had a bunch of recovery machines. I like the Promax the best even though I had an awful time with it when it was new and under warranty. It had an internal leak I had to send it back 3 times to get the same leak fixed. I even had to talk to them on the phone to explain them where the leak was. You'd think something as simple as that would be a no brainer. Despite that, I still like it a lot.
    I had an Inficon before that. It wasn't bad, but the cooling fan blade kept falling off the motor and it drove me crazy. I just couldn't make it stay on.
    Either one, if I'm recovering more than 5 lbs, I always use an after cooler between the recovery machine and the tank.
    Sam
    Know-it-all? Nope, not even half!
    My Yellow Jacket XLT has served me well. It gets alot of use and hasnt let me down yet. Also had an r60a before it.
    Sep 2006
    Leavenworth KS
    Currently using a stinger. It is a hand me down from a tech. The fastest thing I have used yet. Several of our tech's prefer the G5 units even faster.
    Mike
    Hello to All.
    Thank you all for the advice. Is there any PM that these units need to keep them healthy if used only once in a while? I leaning toward the Yellowjacket at this point.
    Thanks again.
    Greg
    The Appion G5 Twin is the fastest recovery machine you can buy that doesn't need wheels to move it around, and is very durable. It also happens to be one of the lightest machines.
    Thank you for the advice. I'll look carefully at this machine. Thanks again.
    Greg
    Jun 2006
    Every company Ive ever worked for issued the promax rg5410. They seem to be pretty reliable. I would really like to try the yellow jacket xlt or a G5
    Jul 2005
    Tulsa
    using a robinair cooltech 25200B with separate liquid/vapor channels.
    pumps down fairly quick...
    Dec 2006
    TN
    I Vote for the Stinger
    I will vote for the stinger. I have a stinger and the promax. I like the stinger, seems a little faster and is also physically a little smaller which makes it easier to handle and takes less room on the truck.
    Stinger, but use a filter on the inlet of any unit.
    Thanks again for all of the input on the recovery units. It seems that all three units are well liked by the technicians answering here. I looked at the Appion G5 today on line and it seems very powerful and fast. I wonder if those who use the G5 really have to cool the recovery tank under normal conditions? At the sale prices it is less than the Promax or the Stinger normally. I'm still not certain but am leaning toward the Appion.
    Greg
