Results 1 to 10 of 10
07-11-2008, 10:01 PM #1
- Jun 2008
- 34
Spine Fin Coils on Trane Condensers
A friend said that Trane Spine Fin Coils look like Snowflakes.
That this "snowflake" grabs dirt, dust, hair, anything like a brush, which is very hard to clean.
He said other coil types grab dirt like a comb, and they are easier to clean because of the coil type.
One guy said to NEVER point a hose of water at Trane coils, because you will bend them accidentally.
Are Trane spine fin coils this fragile?
07-11-2008, 10:06 PM #2
Trane's spine fin coil are much harder and more time consuming to clean...
however, they are no more fragile than your typical coil. If anything, they last a lot longer than a typical copper coil.I fully support the military and the War on Terrorism.
07-11-2008, 10:08 PM #3
- Sep 2003
- 139
07-11-2008, 10:16 PM #4
- May 2005
- Western Kansas
- 255
If regularly maintained (like any system should be), spine fins provide a better efficiency than a fine finned coil. Found some that had been neglected by ignorance and they were harder to clean, but kerosene and hand grenades will fix anything.
07-11-2008, 10:17 PM #5
You can use a hose on them, just be reasonable with the setting and pressure
07-11-2008, 10:23 PM #6
- Jun 2008
- west point, ga.
- 328
I do it with a pressure washer.
07-11-2008, 10:27 PM #7I fully support the military and the War on Terrorism.
07-11-2008, 10:29 PM #8
Professional Member*
- Jul 2008
- Alabama
- 658
07-11-2008, 10:31 PM #9
- Jun 2008
- west point, ga.
- 328
07-11-2008, 10:33 PM #10I fully support the military and the War on Terrorism.
