Results 1 to 13 of 21
    Bryant HVAC System is Frozen
    I have a bryant up furnace. The blower works fine, but the air coming out of the vents is weak. The copper line going into the top of the furnace has ice on the outside and water is dripping on my filter inside. When I pull back the rubber ring around where the copper line goes into the furnace it has ice on the end as well.
    Do I have a clog in my drip line or has the system just been working overtime? If a clog, where do I unclog?
    Thanks a lot
    Northern Colorado
    Check your filters 1st. If they are dirty, then change them, and turn the system off to let the ice melt off. If they are clean, then call an Hvac company. It could be a number of things. Best to ya.
    Hvac Maniac
    "A negative attitude cancels out positive skills."
    Do you think it is my freon?
    DC Metro Area (MD)
    Quote Originally Posted by mshudson View Post
    Hard to tell from here. Being low on freon can cause the evaporator to freeze up, as can other things, such as a dirty filter as mentioned above. Was your filter dirty? Let the ice thaw and call a pro. If it's anything else, a pro needs to attend to it.
    Yes, it was dirty.
    DC Metro Area (MD)
    Yes, it was dirty.
    Then I would let the ice thaw out and then see if things work as normal after. You can run the fan to help the ice thaw quicker (though for a long period I would think that's bad for the blower motor). If it persists then you'll need a service tech.
    Alabama
    Blower motors are designed to run Dude.
    Sounds like the other Dude has a Bryant Heat pump (not Furnace).
    If this is the case, he definetly needs to see a pro.(coil may be leaking freon$$$$)
    DC Metro Area (MD)
    Nevermind... I think I'm wrong.
    Jun 2008
    west point, ga.
    Yeah dude, but are blower motors designed to try to draw air through a frozen evap. coil? That said, it probably isn't a huge deal to run the blower motor once to thaw out the ice.
    There's a video of Payson actually turning the heat on in AZ to thaw out evap. coils in Ruud rooftop units that had frozen up due to plastic being put over the return grills.
    DC Metro Area (MD)
    Would it have any negative impact to run a blower with a frozen evaporator coil? I think I was wrong with what I said above... maybe with a v/s blower when it tries to ramp up to maintain CFM, but for a standard blower I'm not sure.
    Fire the furnace or the heat pump to melt the ice -
    When the air flow out of the registers is back to normal - switch back to cooling.
    If the air filter is clean and the unit freezes up again tomorrow - call your favorite service company.
    Otherwise - no charge: go and sin no more.
    PHM
    Being low on freon can cause the evaporator to freeze up, as can other things, .
    What if instead of Freon, it uses R22 refrigerant instead.
    DC Metro Area (MD)
    You're right. There are more refrigerants that fall under the "freon" category. I was just using the term that the OP used himself.
