Results 1 to 13 of 17
    Aurora, IL
    Use existing lineset, coil with new R410 System?
    Great forum! I'd like to tap into your expertise if I may.
    I plan to replace my existing 3.5T R22 central AC system (14 years old and getting leaky). I'm tending toward an R410-based system (American Standard), but have the following questions:
    1. I hear alot of talk about flushing lines, but can the inside coil also be flushed? My current coil is a replacement installed last spring, so it's only a year old. The fellow who quoted me the 410 system checked the coil and said it was rated for both R22 and R410. I'd like to use it, but am wary given the comments regarding incompatibility of oils, etc. I would guess that coils are more difficult to flush than lines.
    2. Are linesets for R410 systems generally larger diameter than those for R22 systems? I understand the issues regarding flushing the lines, but I've also seen some comments about line sizes being different. If so that would be one reason to bite the bullet and get a new lineset.
    Obviously, for cost reasons I'd like to use the existing lineset and coil. But I don't want to be causing myself problems down the road. Do you guys have any advice for me? Thanks.
    Feb 2007
    Las Vegas,NV
    Some say it's o.k. to reuse the line set if properly flushed but dont reuse that coil. You want one that will be a perfect match for the new unit. Besides I have not heard of anyone on this site reusing an r22 coil for 410 whether it's approved for it or not.
    If the evap coil is 14 years old I would not reuse with R-410a. The increased pressue of R-410a could cause the coil to leak. Do the right thing, and replace the coil. Remember a 14 year old coil has 14 years of gunk built up in it.
    Feb 2007
    Las Vegas,NV
    Quote Originally Posted by craig725 View Post
    You didnt read his post very well, he said the coil was replaced last spring with a 410 approved coil but I wouldnt use it after it has had 22 running through it.
    I would rather have a fresh new matching coil that is perfectly matched up with the new c/u.
    Dec 2006
    Winnipeg-Mb.
    It's like making orange juice out of a recently emptied apple juice container......you just don't do it......same thing with r-22 verses. r-410a..
    don't mix the two ever......the oils don't like each other....
    It can be done,we have done the same on several,no issues.To be safer use a Flush Kit on the coil.
    Should have said,if it's a matching system.
    Jun 2008
    If the Lineset is of the correct size and the coil has the proper R410 TXV valve installed, and the coil is of the correct capacity, why not?
    I would want a matched system. If you have an A-S/Trane coil, then buy the A-S outdoor unit, put a R410a TXV on the coil and you'll be fine. If you have brand X coil, then buy the matching outdoor unit.
    maryland, baltimore
    If cost is the issue, get the highest S.E.E.R, matching R22 unit and ride it out until you change out everything. Although R22 will be phased out, there will still be parts available for quite some time. Mix and match systems may work, but how well and for how long. The cost of making an R410A condenser work with your existing indoor unit may be more than the savings in the long run.
    Quote Originally Posted by sammy37 View Post
    Thanks for pointing that out..I guess I missed that part, I still would not use the coil. If you are concerned, you can request to keep it and sell it on ebay or something if you so desire.
    Alabama
    Quote Originally Posted by DanceAlot View Post
    If you want 14 years out of your new system, you better bite the bullet and change the coil, lineset, and condenser!!!!
    Jun 2008
    Morgantown, WV
    If your condenser is 14 years old then it's probably a SEER 10 condenser. I'm surprised you were able to find a brand new SEER 10 evaporator when you replace it a year ago. If the technician gave you a new SEER 13 coil a year ago to use with your SEER 10 condenser then he wasn't doing you any favors. It's a wonder it would work properly at all. If indeed you did get a SEER 10 evaporator a year ago you will not be able to use it with a new condenser because the new condenser will be a minimum of SEER 13. But, if it is indeed a SEER 13 coil then you can change out the TXV or the restrictor and use it with R410A.
    For the cost of a coil though I'd change it out as well.
    Alabama
    Quote Originally Posted by diverdan View Post
    Dude.... you can't buy a "new 14 year old" 10 SEER coil. A 13 SEER coil will work very well with a 10 SEER condenser. It will boost the overall efficiency of the unit to 11 or 11.5
