Results 1 to 12 of 12
    Houston
    Itís funny what you see on a roof.
    The date on the side of the unit was 2005. I assume no permit was pulled on this job. I donít know what worse the rope on the conduit or the tape on the electrical.
    MN
    A Trane condenser coil with a leak?
    I can't hardly believe it. Was it the 2nd or 1st circuit that is low on charge?
    You can't fix stupid
    Anytown USA
    poor voyager
    DC Metro Area (MD)
    Who said the unit had a leak?
    Anytown USA
    voyagers like to leak right at the bottom of the coil at the metal tubesheet.
    looks to be a small oil stain there. so he was guessing that there was a leak.
    Panama City, FL
    I can see where you would be concerned if they used tape or rope. But, they used tape and rope; so it's good.
    It's all in how you interpret the code.
    You can't learn a thing with your mouth open.
    DC Metro Area (MD)
    Quote Originally Posted by y7turbo View Post
    Duly noted. I didn't know that (not surprisingly).
    Oct 2005
    Kermit, TX
    My guess would be roofers. They're bad about rigging stuff like that.
    Zach
    Arizona
    Looks like an experienced Goodman installer tried his skills on a commercial job!
    I've had my fair share of fixing leaks in that exact spot.
    Sometimes you get the other Voyager variety where the distributor tubes coming off of the OD TXV will rub and leak. All my experience on leaking tubes on Goodman Heat Pumps prepared me to fix them in the Tranes. At least Trane made an ATTEMPT to zip tie their tubes so they wouldn't rub holes in themselves.
    True Heavy Metal Geek
    omaha
    Talking
    looks like brick on the conduit ? is that to keep tension on the rope are the tape
    Dec 2006
    Massachusetts
    Quote Originally Posted by 4x4freak View Post
    beat me to it...damn roofers
    Jun 2007
    Darby, PA
    This definately looks like the roofers were here. Did they also break the condensate trap off too? The roof looks recent.
