Page 4 of 9 FirstFirst 123456789 LastLast
Results 40 to 52 of 112
  1. #40
    Dec 2006
    Northern VA
    Did someone say something about naked cheerleaders?
  2. #41
    DC Metro Area (MD)
    Quote Originally Posted by Freezeking2000 View Post
    Zip ties do not last nearly as long as good electrical tape.
    Didn't know that. Thanks... Even good black zip ties? I guess I could see good electrical tape holding up well.
  3. #42
    Dec 2006
    Winnipeg-Mb.
    Quote Originally Posted by acobra289 View Post
    Assuming you don't want to keep your reasons secret, is there anything that can be brought to the attention of the company to have it corrected? Or are your reasons based on cosmetic issues?
    As for the disconnect box, if it passes inspection, great, If not, it doesn't seem that big of a deal to move it to where it needs to be.
    Concerning the condensate drain freezing during winter, what is the usual solution to this problem? My last furnace was an 80, so I have not dealt with this before.
    Any other issues I need to bring to their attention?
    Thanks.
    1-Gas supported to appliance.....
    2-condensate breather for proper pressure and flow..
    3-is that armour flex joining the evap drain and furnace condensate?
    4-I perfer to put in-take outside for better efficiency...
    5-clean the electrical wires up...{from the old t-stat wires join the new}
    6-the dryer vent is to close to the condenser for my liking....nothing like plugging the condenser up with lint....
    thats just to name a few things......
  4. #43
    Alabama
    Quote Originally Posted by wpg_hvac-r_redseal_ View Post
    those IDIOTS used armour flex to keep the floor from getting wet when the drain sweats. furnaces have positive pressure drains, therefore p-traps are not needed. they do need to be capped.
    the Dude stated in an earlier post that the furnace drain and the a/c drain need to be seperate, He's 100% right.
  5. #44
    We don't do a lot of furnaces,the only thing I'd change is the way each return enters the furnace.May not be an issue ,but lower static would be gained,but may not be needed,can't tell from here.
    Have the static checked,is the best advice .
  6. #45
    Nov 2001
    Seattle, WA
    Quote Originally Posted by superd77 View Post
    Or at least an air gap after the condensate trap. Surprised no one has focused on that as it's a safety hazard. It's a direct connection between the heat exchanger and the supply air.
    - Alexis de Toqueville, 1835
  7. #46
    Quote Originally Posted by DeltaT View Post
    If it wasn't on a positive pressure drain, and ran further then it does, it would be a concern.
  8. #47
    So it's not really a concern?
    And what is this armour flex they speak of? Is that the black pipe insulation on the trap?
    Thanks.
  9. #48
    North Carolina
    How much clearance is there between the wall and the unit? Looks too close from the pic..
  10. #49
    Jun 2008
    west point, ga.
    Thanks.
    Yep
  11. #50
    Houston,Tx.
    Is that a garden hose next to the condenser?
    Is that writing on the insulation covering the return air? OMG!!
  12. #51
    DC Metro Area (MD)
    Talking
    He's gonna need it with the drier exhaust and that spine fin.
  13. #52
    Houston,Tx.
    O so we can we chalk that up as a good thing about the install?
    I know I am terrible I try to find some of the good things in life.
