Page 9 of 9 FirstFirst ... 23456789
Results 105 to 112 of 112
  1. #105
    Ct
    Quote Originally Posted by aintitfun View Post
    Well that, and dont forget about the moon alignment.
    That wasn't my first choice tho. My first choice was to paint the DC the same color and pattern as the bricks, then hang a picture of a DC down the wall a bit.
    BUT, if we have to deal with the moon, THEN FINE, we'll move the freakin moon, lmao. If we bring the moon in close enough, maybe it will eventually slide the CU over a bit the same way it affects the tides.
  2. #106
    Anytown USA
    you just droped your efficency way down.
    explain why and how.
  3. #107
    The combustion air intake need to be piped in outdoors, I've seen way too many contractors pull this crap, you need to get that fixed you just droped your efficency way down.
    And how did the efficiency drop because he's pulling garage air?
  4. #108
    Apr 2008
    TEXAS
    Quote Originally Posted by DPSwitch View Post
    Most of it is housekeeping issues with a few exceptions. The gas line I wouldn't leave like that long enough to walk to the truck. Some things the other guys mentioned I didn't pick up on myself so I learned something.
    I would just suggest to the OP that what you are witnessing in this thread is how we collectively push each other to a higher level in what we do. There isn't quite as much malice here as it might seem. This is what we do, then we all come out of the woodwork to try to help each other in a bind... I see it over and over.
    does that mean i don't need help? i feel so relieved.
    "When the people find they can vote themselves money,that will herald the end of the republic" - Benjamin Franklin
    "Government is not reason, it is not eloquence, it is force;like fire, a troublesome servant and a fearful master. Never for a moment should it be left to irresponsible action"- George Washington
  5. #109
    Jul 2001
    VA
    Quote Originally Posted by smittyii View Post
    There have been a few issues raised I think should be addressed.
    ___________________________________________
  6. #110
    Apr 2002
    well, it is a definite improvement over the banned Ultravent
  7. #111
    condensate drain line
    Quote Originally Posted by acobra289 View Post
    Assuming you don't want to keep your reasons secret, is there anything that can be brought to the attention of the company to have it corrected? Or are your reasons based on cosmetic issues?
    As for the disconnect box, if it passes inspection, great, If not, it doesn't seem that big of a deal to move it to where it needs to be.
    Concerning the condensate drain freezing during winter, what is the usual solution to this problem? My last furnace was an 80, so I have not dealt with this before.
    Any other issues I need to bring to their attention?
    Thanks.
    the drain line 1/2 inch plastice pipe shoud be used from condensate pump must be drain into the sump pump or sink otherwise it woild freeze up in the winter time
  8. #112
    not really
    not it doest have to be piped outside its called direct venting use inside air for combustion it does not affect the efficiency of the unit
