Page 1 of 9 12345678 ... LastLast
Results 1 to 13 of 112
    Pics of install - let the comments fly
    Okay, here are some pics of the new equipment and a few of the old also. Please post your comments, questions and criticisms. Let me know if any specific or close up shops are needed and I'll try to post.
    Trane XR14 HP w/ 90% XT furnace.
    Old inside
    Old outside. I think I had a good 5 years left in this unit.
    A few shots of the new inside equipment.
    A few of the outside unit.
    That little copper tube coming out the bottom there is the condensate drain.
    Altmar, New York, United States
    looks good. where does the air filter go?
    Jul 2001
    VA
    Yowza.
    ___________________________________________
    Nov 2001
    Seattle, WA
    It's pretty but looking I see the condenser is sitting directly in front of the disconnect and that's a no-no. And I just don't like the A/C condensate and the furnace condensate tied into the same line where backflow can be possible. It's pretty though and I like the furnace and condenser pad install.
    - Alexis de Toqueville, 1835
    Quote Originally Posted by DPSwitch View Post
    Yowza.
    Is that "yowza" in a good or bad way?
    Quote Originally Posted by DeltaT View Post
    Is there a reason the disconnect shouldn't be directly behind the unit?
    My concern about the drain line was that it empties right at the foundation of the house and also right at the pad.
    Thanks for the complement on the pad. I actually did most of that the day before they came. The old unit had sunk down some, so I needed to get it raised up some. I laid 3 sides and left them room to remove the old unit. Then finished it up while they were doing some inside work.
    I also noticed they used electrical tape to wrap the pipes outside. I assume there was a better way to do that. That tape won't last long outside.
    Jul 2001
    VA
    The gas line needs better support.
    The Yowza was for the old stuff.
    It was a good investment.
    I don't know
    How come the combustion air intake doesn't terminate outside?
    I've discovered a natural law - everything gets progressively worse. Things only break down and become depleted. Life isn't worth living and everything is going to hell.
    Death is the messiah. Everything else is irrelevant and arbitrary.
    DC Metro Area (MD)
    http://i243.photobucket.com/albums/f...9/100_3140.jpg
    Is the pipe in this photo for the furnace exhaust?
    Sometimes installers use electrical tape outside when zip ties would be better. You could always get some black zip ties at a hardware store down the road if the electrical tape goes bad.
    All things considered, I think it looks pretty good for the most part... There's a difference between looks and performance, as well as code.
    burlington county n.j.
    indoor air for combustion...
    whats going to keep the drain pipe from freezing in the winter??????
    never ever use copper for the drain on a 90% furnace, the condensate will eat it up...
    there was plenty of room to get that other filter case in there if they had used beenthere's design for the return box.....
    Quote Originally Posted by acobra289 View Post
    violates electrical code and will not pass inspection around here.
    did they get permits??
    N.E. Ok.
    Yeah disconnect behind unit, not code.
    need to be able to access it without coming into possible contact with unit.
    Is that a dryer vent exit in the window to the left of the unit
    oh yea, nice pad work there
    Fort Worth, TX
    Is that a dryer vent poking through the window to the left of the condensing unit? If so, not a good combination to have a dryer vent and an air breathing condensing unit nearby. Especially since that Trane has spine fin coils, which attract dirt like a magnet. Great heat transfer when they're clean, but not so hot when it's dirty.
    At a minimum those coils should be cleaned yearly. WIth a dryer vent nearby, make that more often.
