Results 1 to 13 of 21
07-11-2008, 01:39 AM #1
- Jul 2008
- 9
Low pitched hum from furnace blower when AC cycles on
Hello all. Glad to be a new member of the site
. I have a 15 year old York furnace, mod#P2MPD14N08001B 115v-1PH-60hz. The York A/C unit was replaced about 3 years ago with a Frigidaire FS5BD and evap coil C3BA-048. At the time the A/C and evap coil were replaced, the tech also removed the blower wheel for cleaning. One thing I've notice since the repacement A/C and evap, is that everytime the A/C cycles on I can hear a low pitched hum resignating up through my bedroom floor as my 8'X8' utillity room is just below. The noise is only present when the A/C is on. With just the fan in "on" or with heat during the winter, I do not hear it. At first, I thought it was sound resinating from the outside unit that's located just below my bedroom window (one story down), but when I place my ear directly to the floor carpet area where the furnace is located just below, the hum can be heard loud and clear. This past weekend, I replaced the 15 year old blower motor and run capacitor thinking it might be showing it's age with noise, but the hum is still present. I thought that I could live with it, but I'm a light sleeper and find the hum somewhat annoying everytime my A/C cycles on, while trying to fall asleep. Any input would be greatly apreciated. Thanks
07-11-2008, 02:08 AM #2
Waiting Email Confirmation
- Mar 2004
- 60
if sound is not present without cond unit running sound like a possible vibration in line-set.was this replaced also?
07-11-2008, 06:14 AM #3
Not an uncommon complaint with an A/C that has a scroll compressor.
07-11-2008, 11:22 AM #4
- Jul 2008
- 9
The lines were not replaced, however one thing, I thought lowered the sound just a bit, I removed the line-set holding bracket that secured the line to the floor joist. I thought it was vibrating sound up through the floor. At first it seemed liked the sound deminished a bit, now I'm not too sure. Should I have had my lines replaced? Can 14 year old lines become noisy? I didn't here a peep out of them with my old York A/C unit and evap.
07-11-2008, 11:26 AM #5
- Jul 2008
- 9
07-11-2008, 03:37 PM #6
Isolate the lineset from the building. You probably did help it manipulating that bracket. Changing lineset wouldn't change things unless they were run differently. Your oldie didn't have a scroll which is why you didn't used to hear it.
07-12-2008, 12:04 AM #7
- Jul 2008
- 9
07-12-2008, 12:21 AM #8
Professional Member*
- Jul 2008
- Alabama
- 658
Hey Glenn, try this.
Turn the a/c on. Go outside. Turn the power off to the outside unit.
Go inside to see if the noise is still there. If it is, there may be duct issues when they changed the coil. If not, the scroll compressor is the answer.
Vibration limiters could be put on the outdoor unit to make the noise tolerable.
I did see this once..... we tried everything to quiet a unit down. Turns out that the condenser fan motor was the culprit. Had a bad bearing causing the noise.
07-12-2008, 12:25 AM #9
- Jun 2008
- west point, ga.
- 328
Back when I was in the gas business we used fiddle sticks.
07-12-2008, 12:28 AM #10
- Jul 2008
- Alabama
- 658
07-12-2008, 12:32 AM #11
- Jun 2008
- west point, ga.
- 328
Everybody knows what fiddle sticks are.How long have you been in hvac?
07-12-2008, 12:35 AM #12
- Jul 2008
- Alabama
- 658
07-12-2008, 12:38 AM #13
- Jun 2008
- west point, ga.
- 328
All is well my son.Seriously i vote vibration limiters.
