Results 1 to 13 of 16
Thread: 3-Ton Unit Efficiency
07-10-2008, 08:19 PM #1
New Guest
- Jul 2008
- 4
I am wondering if my unit is doing all that it can do. After we added on to the house, it seems like its more difficult for the house to cool off. The unit is a Armstrong 3-ton about 12 years old. Today, I done a little checking. It was 84 degrees outside. The humidity was probably about 60%. I measured the temp at the register that was the most distance from the unit and it was 64 degrees with 90% humidity. The air at the closest register was the same. The air at the return was 73 degrees at 60% humidity. That's only a 9 degree difference. Also, is there a simple way to check to see if my air flow is sufficient. Any ideas would certainly be appreciated.
07-10-2008, 08:23 PM #2
This is not a DIY site, but I can tell you that when you add more load to a system, that system works harder.
Check for insulation problems on the ducting that runs through unconditioned areas. Check you air filter. That's about it for HO testing.Government is a disease......masquerading as its own cureEcclesiastes 10:2 NIV
07-10-2008, 08:31 PM #3
Measuring temps at the registers seldom tells you anything.
Have a service tech check it.
07-10-2008, 08:33 PM #4
- Mar 2005
- Houston, Texas
- 11,646
07-10-2008, 08:38 PM #5
07-10-2008, 09:25 PM #6
- Mar 2005
- Houston, Texas
- 11,646
07-10-2008, 08:43 PM #7
07-10-2008, 09:26 PM #8
- Mar 2005
- Houston, Texas
- 11,646
07-10-2008, 09:03 PM #9
New Guest
- Jul 2008
- N.C.
- 2
Uncomfortable
Sounds like you added on, and robbed your other supply's for air.Big no,no Your system was'nt designed to handle the addition. 12 years ago, yeah today ,no. Sorry man you need a bigger system.
07-10-2008, 09:06 PM #10
- Jun 2008
- west point, ga.
- 328
Who done your duct work to your addition?
07-10-2008, 09:23 PM #11
New Guest
- Jul 2008
- 4
The original duct is insulated metal duct, but the extension from the original placement of the unit to where it is now is flexible insulated tubing. The house is 2-story with a separate system for the upper floor. The bottom story sq footage is about 1600sq ft., but a lot of the spaze is open except for the great room which has 18ft cathedral ceilings with the ceiling fans. I would have thought that a 3-ton unit would have been sufficent, but my air flow doesn't seem all that great.
07-10-2008, 09:27 PM #12
Professional Member*
- Jul 2006
- Virginia
- 3,716
was the system running the duringthe remodel
07-10-2008, 09:30 PM #13
- Jul 2008
- 54
