    Jun 2008
    Controlling one return flow... to drop thermostat and to cycle.
    First floor, I have two tons and 4 returns.
    The dining room has my thermostat.
    Dining room has one supply and one return.
    Supply is on the furthest wall. Return is on the wall between supply wall and thermostat wall.
    My feeling is that the return is sucking out the cold supply air before it can reach the height of the thermostat. Both the return and supply are on bottom of wall, same height.
    Problem. I need the Stat to cycle more. Air just runs now, because the cold air is being sucked out.
    Ideas?
    I am thinking about getting one of those vent magnets that cover the registers. Placing it over the dining room return. Reducing the total returns to 3 on a two ton unit.
    I need the cool air to stay in the dining room, to drop the thermostat, so it cycles.
    What about using the plastic air deflectors? Point it up or down?
    Thinking about putting a big wooden chest two inches in front of return, just to slow down the suction out of that room.
    Putting holes in a magnet vent cover, so that return still works but not at 100%.
    Lancaster PA
    Put the cover on the supply so it throws the air up.
    If you choke down that return. You will also lower teh amount of air coming out of the supply registers. Doing more harm then good.
    Take a candle and see how little the return infulences airflow ,and how much the supply does.
    Jun 2008
    Deflector facing up on the supply vent. I think, I tried that once, I will try again right now.
    Lancaster PA
    Lot of homes around here have supplies low on teh wall. The deflector throwing the air up works best for getting good room cooling from them.
