Results 40 to 52 of 54
Thread: oversized. Now what?
07-10-2008, 08:00 PM #40
- Jun 2003
- 115
so, I assume that means something is not quite right. I have not had any service done to the AC in the 5 years I have had it. maybe a standard service call? Would that involve the tech diagnosing this problem, or is that extra time and money?
Is AC something that needs regular service?
07-10-2008, 08:22 PM #41
They should be checked every year.
If you don't tell them its having trouble. They may not catch it.
Tell them its not working right over the phone, and that you want it cleaned and serviced at teh same time.
If you don't. It would be possible, a new tech would come out, and not know how to diagnose it.
07-10-2008, 08:39 PM #42
- Dec 2007
- Cedar Grove, Wi-Sheboygan
- 1,582
In would have someone come and check your duct system, that would be the first thing I would do. Next I would probably have another return register put in since you mentioned you have a ranch style home, and if your one return register is not centrally located I would see about having another put in, Maybe even consider having some high wall return registers installed thru out the home. Get your air flow issues resolved, do you have dampers on all your heat runs ? If not that would be another itme you should think about having done. Once you have doen most of those or all of them then have the air flow balanced and see how your home is afterwards if it is better than it is now and if not then it may have to be downsized.
07-10-2008, 08:47 PM #43
If he does all that. Then he will have paid to increase his humidity.
07-10-2008, 09:29 PM #44
- Jun 2003
- 115
yeah, actually, my home is pretty open, the return is well place, I think. I have lit inscence around and no matter where in the house I have it, when the fan is on, the smoke moves toward the return. It is a small house, only 1100 square feet with 8 ft ceiling and a basement.
I will however seriously consider having a tech take a look at it. but as you said in a previous post, what i fear is that the guy comes and just gives me a line that 'everything is fine", b/c that is pretty much what happened when I instlaled the AC.
But if i do as you say and make sure to point out the particular issue that possibly a safety is shutting the system down during long run times, hopefully the tech can dianose the issue.
what other things do they do for the cleaning/service? no need to list everything, what are the major things that the tech does?, or "should" do?
07-10-2008, 09:38 PM #45
After 5 years, your coils most likely need cleaned.
Should check blower and fan motors.
Refrigerant pressures and temp.
Air temps.
Check drain lines.
Etc.
07-11-2008, 02:47 AM #46
OK; but what about my question?
In terms of heating - how much less will the highest efficiency HP system cost to operate versus the lowest efficiency HP system?
13 SEER heat pump
15 SEER heat pump
How much less will the 15 cost to operate than the 13?PHM
When faced with the choice between proving that their opinion is correct and changing their mind to fit the evidence - most people get right to work on the proof.
07-11-2008, 04:00 AM #47
Waiting Email Confirmation
- Mar 2004
- 60
oversized
1100 sf 3 ton up state ny?????? do you have no windows doors insulation....etc? or do you enjoy your system turning on and off every 4 mins? HELLOOOOOO LOAD CALC.!
07-11-2008, 04:10 AM #48
- Dec 2007
- 1,582
Beenthere why would he have paid to have his humidity increased after doing all that I suggested ?
07-11-2008, 07:09 AM #49
I wrote an answer.
Apparently I must have clicked something other then post, cause it ain't here.
Do you want just a blanket percent.
Or a print out performance.
13 to 15 SEER single stage can get you 11% on the HP alone.
It comes out a little more if you figure in the savings from the aux heat not having to be used as much.
So you can see an easy 15% reduction in energy consumption for the year.
Keep in mind. HPs weather 13 or 15 SEER, from one brand to the next, have different BTU performances.
One manufacturers 16 SEER does worst at heating then their 14 SEER.
07-11-2008, 07:55 AM #50
- Jun 2003
- 115
A post like this aught to be looked at by the forum moderators. After the length of the thread and the information given, for this jackal to say this to me is both rude and obnoxious.
It has been a pleasant converasation up until this point and I appreciate all the reply's so far, but this one just sits with me the wrong way.
07-11-2008, 08:03 AM #51
Unfortunately.
Some people forget that the customer(yourself) is not the person that was suppose to know to do(or should have been done) a load calc. And it was the responsibity of the contractors you called to do it. And that in many areas contractors not only don't do them, but many don't know how.
07-11-2008, 09:54 AM #52
Yes; it is rude and obnoxious. On the otherhand -
PHM
